PTO--does on/off hurt engine
   / PTO--does on/off hurt engine #1
AppleMan
Northern IL/Southcentral WI
JD 2305, JD 850, 1951 Farmall
Does shutting the pto on and off hurt the tractor's engine? I have to shut it off on about half of my turns at my orchard (ground is severely uneven in these spots) and didn't know if it would hurt the engine. In three hours of spraying I probably turn it on and off about 20 times.
   / PTO--does on/off hurt engine #2
I can't imagine how it could. Perhaps there are internal clutches that are getting worn or something (I would think this would be tractor dependent), but that would be about it. If you are only shutting down the PTO when turning around, why not leave it engaged and save the worry?
   / PTO--does on/off hurt engine #3
There would be more risk of damage letting it on from the vibration in the turn
The only thing you could hurt turning it on and off would be the PTO clutch and I wouldn't worry about that
   / PTO--does on/off hurt engine #4
Can you tell me what is meant by vibration in the turn?
   / PTO--does on/off hurt engine #5
Sorry, I guess I assumed the OP was talking about a rear PTO shaft in which in a sharp turn the U-joints produces a vibration
   / PTO--does on/off hurt engine #6
I think I'd save my pto clutches and invest in a CV style rear pto shaft!
soundguy
   / PTO--does on/off hurt engine #7
If you were running a rotary cutter or finish mower, I'd say you should not cycle the PTO ON/OFF. However, if you are running a PTO pump for a sprayer, it probably does not have anymore starting torque than a posthole digger. That would probably not put a lot of stress on the PTO clutch or the tractor's engine. So my answer is that if there is little torque required, go ahead. If there is a high torque requirement, then raising the 3PH in the turns might be the best option.
Thanks much. It is a trailer mounted (not 3pt hitch mounted) in which the pto powers the pump for the sprayer so I'll keep shutting it off on the sketchy turns.
   / PTO--does on/off hurt engine #9
Just checking, but are you using your Clutch to dis-engage (and engage) your PTO on and off? You need to with Transmission Driven PTO (not with Independent PTO).
Not using your clutch is the only thing I can think of that would hurt your engine by jamming it on or off. Don't mean to talk down to you, just checking.
2018 F550 Bucket Truck (A56438)
2018 F550 Bucket...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
2024 CASE TV450B SKID STEER (A60429)
2024 CASE TV450B...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
Cushman Cart (A59231)
