PTO hookup- Is it just me?
   / PTO hookup- Is it just me? #21
My Massey [1433v] has a lever on the back of the tractor, this lever engages the pto if i turn it off the pto spins either way freely.
Also for me, my stump grinder is a pain to hook up, so i align the tractor and stay about 1 1/2' back then i connect the pto shaft then the stump grinder.
Shane
   / PTO hookup- Is it just me? #22
There's no semi-conscious about it. I am fully conscious of my disdain for this task.
My trick is to keep it greased and curse at it like a wounded sailor.
Funniest thing I've read all day!
   / PTO hookup- Is it just me? #23
I keep a couple pairs of surgical gloves in the cab. That way when I'm done attaching the pto shaft I can just remove the gloves and not have to go wash up.
   / PTO hookup- Is it just me? #24
I let my wife do it! When we had the rear mower.
   / PTO hookup- Is it just me? #25
The PTO shaft also should have a grease zerk. Be sure to keep it greased with a synthetic (for cold areas) grease so it will extend and retract easy.
The other thing is to just do it more. The first 50 times were a chore, the next 50 a bit less and after that not too bad!
jb
   / PTO hookup- Is it just me? #26
With the pto disengaged, my pto shaft turns by hand. So, it's not quite the chore of other machines. I think repetition helps also. As far as the coaxial parallelism, well I don't know. I generally am just hooking up a bushhog or disc and not doing trigonometry.:)
   / PTO hookup- Is it just me? #27
The only problem I seem to have is that with my wood chipper, there is only one position where I can connect the PTO shaft.
I have taken a file to both the spline and the implement attachment, but it still only works in one position.
I haven't had the snowblower long enough to know if this problem is unique to the chipper, but I have never had this happen on other tractors.
Every time I change implements, I can see why folks often use the Pat's or some other system to make this an easier chore. I find that getting the draw pins and 3PH properly aligned is a huge PITA, which makes the PTO issue seem like just a minor inconvenience.
My solution is that I try not to make too many such changes. :rolleyes:
Jay
   / PTO hookup- Is it just me? #28
Don't tell anybody, but I cut the shroud portion off the protector sleeve because of this problem.
Made a world of difference in hooking it up. And it's still protected by the tractor metal shield.
Ditto
   / PTO hookup- Is it just me? #29
I use a tire iron slipped thru the u-joint to help extend the shaft and turn it if needed. i use the pto shaft cover tie chain to suspend the shaft at about pto level anyway so I don't have to hold it up.. bunji cords are great for holding toplinks and shields out of your way..
soundguy
Hello All,
Whenever its time to put on the rotary cutter, I find myself semiconsciously dreading the PTO shaft hookup. Not so much locking the shaft on, but getting the splines aligned is the trick. Its a combination of things- no good place to stand; ducking the top link while sidestepping the bottom link; needing both hands to extend the shaft while needing a third hand to rotate the stub spline; or difficulty rotating the shaft while trying to extend it- all these things complicated by protective shrouds on both the tractor and on the PTO shaft that reduce the ability to get a good grip.
To the tractor designers- I'd gladly trade my factory cup holder and cruise control for a better hookup system. Does anyone else have this problem?
John
   / PTO hookup- Is it just me? #30
Lotta good tips in here that I'll be trying. :D Bunji cords, tire-irons, removing covers, lotta good stuff.
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
ROLL OFF BOX (A53843)
2013 FORD F-350 (A53843)
2013 FORD F-350...
