PTO HP in different ranges.
   / PTO HP in different ranges.
normde2001 said:
You will only have pto, (15), hp available to run the generator, giving an effective 7.5kw. If it's just a bare head, connection and gearing should be a real challenge.
Norm
It is a bare head.
I work in a 500 machine, machine shop, I have 300+ straight cut gears to choose from, from an old automatic screw machine that we scrapped to achieve the ratio.
My plan was to fab a countershaft using pillow blocks and 2" square tubing, mounting the entire thing to and old dirt scoop frame. I found a PTO adapter at TSC that I'm going to bore out to the counter shaft size and have one of my guy's at work broach a keyway into.
I will probably loose some HP through the gearing, but I don't need to power a city. All I need is a backup that is capable of running a well pump, furnace blower motor, TV and a couple of lights.
I live in a very rural part of northeast Ohio and when the power goes out, they generally aren't in much of a hurry to get us back on line because of the number of people affected. So normally our power is out up to 5 hours at a time.
I probably could use a small gas generator, but I got a very good deal on this head. It cost less than a small generator 4KW and all of the parts to make the rest were picked out of the scrap pile.
Thanks all!
Tom
   / PTO HP in different ranges. #12
I think a flywheel would help with the load/unload response, wouldn't it?
If you're gearing up (from 900 on the tractor PTO to 1800 at the genset) it affects torque and HP too, doesn't it? It's like trying to run up a hill in 4th gear vs 2nd............
   / PTO HP in different ranges. #13
Tom, it sounds like you could get by with about 5kW power output or a little less. I've used my RV genset, 4kW to run the house, 1HP well pump, several refrigeration units and a few lights without difficulty.
For Yanmar first 2 digits on model number represents PTO hp.
May I suggest you give thought to not using gears and go with a belt drive. Not much diff in efficiency and most likely going to be a lot quieter. Additionally since you are not going to be taxing the generator too hard with stated loads, you have the option to "gear" the drive so engine doesn't have to run near full speed. At a latter date if load demand changes or you get another tractor, a belt drive would be easy to change drive ratios to occomodate changing conditions.
I have sim plans for a generator but was thinking of 7.5kW size. Was going to drive the unit so engine would only turn about 1200 rpm but I'm also starting out with a larger tractor and smaller generator.
Update
I traded for a 7.5KW unit. It should provide all the power I need and should fit the HP of the tractor better.
I took the advice of belt driving it.
All I have to do is build the drive unit.
I have attached my plans, anyone see any problems?
Tom
  • final.pdf
  • final2.pdf
   / PTO HP in different ranges. #15
If you are running near rated hp / rpm.. and you do have 18 pto hp available.. then in idal terms.. you can get about 9kw out of the head. That will be reduced depending ont he connection method. as was mentioned.. belts will loose the most.. gear driving/ gearbox, the least.
In any case.. looks like you may squeeze 7-9kw out of the head, depending on how you go about it..
I think your plan with the smaller head is pretty good. One question though. Do you plan to add a front shaft support to help with the shaft side load o fthe belt on the genny shaft? Thus having hte genny pully supported on both sides of the pulley?
Soundguy
F15DOWNER said:
Sorry for the confusion. The model is F15D which is around 18HP according to Hoye's web site, which I have great confidence is right.
The generator is a 10K.
My PTO is three speed, 600, 916, 1200 roughly
My plan was not to run it direct, but a 2:1 or 3:1 or something in between, ratio depending on the outcome of this conversation.
After hearing what I have so far I think I will run 916 PTO speed and select a ratio that will give me 1800 RPM at about 2200 engine RPM which should be real close to 2:1.
I know that 10K is pushing it on HP, that is why I'm doing my homework, with the people that I am very confident that know.
I would rather have a generator that runs under the rated output with this tractor so when I upgrade the tractor sometime in the future it will be just right. (hopefully soon)
Thanks for the reply's so far and if anybody else has any input I will be very grateful.
Where are you soundguy? I always look forward to your input.
Thanks again
Tom
I thought about supporting the Gen shaft and I have a plan to do it, if I need to.
The shaft size is 38MM (1.496") and the front bearing is very stout, so I was hoping to get away with not doing it.
This generator is a tank. It's all cast iron, with roller bearings.
I have Applied, quoting me 2 38MM pillow blocks today, the only problem is the input shaft is kind of short, to get one on the outboard side.
Thanks
Tom
Soundguy
   / PTO HP in different ranges. #17
Your choice of course.. but I've seen bearing failures in side loaded belt driven apps i fthe belt tension is too high.
For limited use.. it may not be a concern.
Soundguy
   / PTO HP in different ranges. #18
I'm just thinking about the theoretical here - I think the reason some larger US tractors have a 1,000 rpm pto is to tradeoff a higher pto rpm for lower torque transmitted. I assume that improves reliability.
This same reasoning might apply here. Running your pto at intermediate speed is going to require a robust step-up belt system to drive a tiny pulley from a large one. But if you use the pto's highest gear then the pulleys will be similar (3:2), and at the higher driveshaft rpm there will be less torque stress to design for in building the coupling, and also the mounting.
Is there a Mechanical Engineer in the audience?
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
2020 Genie TZ-34120 (A50123)
2020 Genie...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
