PTO HP on an X585?
   / PTO HP on an X585? #1
JJE64
X585
Does anyone know what the rated HP is on an X585 540 rpm rear PTO? I am guessing about 17 hp based on the engine is 25 hp.
Also, would this tractor handle a VERY small rotary cutter? KK and Fred Cain make 40" units that weigh about 380 lbs. I have a small area that needs rough cutting every year and using one of these on the X585 intrigues me.
Thanks
John
Thanks
John
   / PTO HP on an X585? #3
I have seen the 40" cutter work well on these units. I assume you have the PTO and 3-point?
   / PTO HP on an X585? #4
   / PTO HP on an X585? #5
I have a 445 with the 22HP Kawasaki, and it is rated at 19 HP at the PTO, so I would expect the X585 to be around 21-22HP at the PTO.
Have you tried mowing the area with the deck lifted as high as it will go? I have about 4 acres that needs to be knocked down a few times a year, and the 54" deck actually handles it pretty well. I've been thinking about the rear PTO, 3PH and a small rotary cutter, but this low tech. solution seems OK for now.
Woods also makes a series of attachments for the "estate tractors". The key limit will be the 3PH lifting capacity, not the HP.
Good luck.
Rob H.
   / PTO HP on an X585? #6
Good luck.
Rob H.
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
