PTO HYDRAULIC PUMP SIZE
   / PTO HYDRAULIC PUMP SIZE #11
With a cylinder that size, may want to consider a regenerative valve.
There's a prince regen log splitter valve here...Prince LSR Rapid Extend Logsplitter Valve - Cylinder Services
There was a post about this earlier in the year: http://www.tractorbynet.com/forums/hydraulics/136227-regenerative-logsplitter-valve.html
Don't know if you could combine a regen valve with a two stage pump. With a 6.75 bore, would be nice to get all the speed you can, even if it's only in one direction.
On the description for the prince regenerative log splitter valve, it specifically says NOT to use it with two stage pumps. It is aimed at tractor hydraulic powered spiltters.
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A52128)
2023 MAXXD TDX...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2015 DODGE RAM...
