Pto lift arm only go half way
   / Pto lift arm only go half way #1
daisey32
Ny
John Deere 3520
I have a john Deere 3520 and the pto lift arms only go half way up. The front buck works and so doesn't the belly mower pto work. There is a big yellow cap Behind the seat that I unscrewed and there is pretty much empty. Is this suppose to be full? I can lower and raise the lift arms half way but not enough to lift a brush hog or me standing on them based the hLf way mark. And advice?new to tractor?
Mike
   / Pto lift arm only go half way #2
Do you also have a draft control lever or knob in addition to the standard lift lever on that particular unit?
I am a newbie. Just got my tractor used from a john Deere dealership and they are suppose to be getting me a manual. I am guessing you are talking about the black round nob in the front. I turned it one way tried it then turned it all the way the other way. To me it seems like it controls how fast the bar goes down. But it only comes up half way. Does it need more hydronic fluid?
   / Pto lift arm only go half way #4
It never hurts to check the fluid level with all implements in the down position but if your FEL works correctly there is probably enough. Does your unit have a additional lift handle on the outside rear of the tractor to lift and lower the arms while attaching a implement? I am just trying to figure out what you might have on your set up that may need to be adjusted.
   / Pto lift arm only go half way #5
operators manual = most likely tell you were locations are to check for fluid levels and how much and what type of oil to use.
jdparts.com = online parts manual
shop/service manual = better diagrams and descriptions of how to tear stuff apart, test stuff as you go, and put it back together.
with above said. operators manual ya best bet at this point.
if ya half way mechanically inclined would suggest getting the "shop/service manual"
Does anyone no where I should look for the viewing glass to see if it needs more hydraulic fluid? My manual is on back order
I ordered a operating manual already. Just waiting for it to come in the mail
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
