pto problem on 2015 john deere x 300
   / pto problem on 2015 john deere x 300 #11
Wow- a lot going on in that this thread? First of all I wouldn’t be moving too much dirt with your plow on an X300. The X300 is a fine machine, but it has a K46 tranny. Secondly what the big deal in removing the deck? Why would you be “dreading” that? JD 48 inch decks are a snap to take off. Casters turn easy to disconnect and roll out from under tractor- I can take mine off in less than 5 min. Third 1st thing I do with any problem troubleshooting is check connectors, clean/reseat all connectors etc- always try the easiest thing first. 4th why would you use E85 gas in your lawn mower? Your tractor is not designed for E85 fuel- it may even void your warranty
For those of you that dont know what E85 fuel is, its a term that refers to high-level ethanol-gasoline blends containing 51%-83% ethanol, depending on geography and season. It can be used in flexible fuel vehicles, a John Deere 300 and its kawasaki engine is definitely not a FFV.
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
