pto problem on 2015 john deere x 300
   / pto problem on 2015 john deere x 300 #11
Wow- a lot going on in that this thread? First of all I wouldn’t be moving too much dirt with your plow on an X300. The X300 is a fine machine, but it has a K46 tranny. Secondly what the big deal in removing the deck? Why would you be “dreading” that? JD 48 inch decks are a snap to take off. Casters turn easy to disconnect and roll out from under tractor- I can take mine off in less than 5 min. Third 1st thing I do with any problem troubleshooting is check connectors, clean/reseat all connectors etc- always try the easiest thing first. 4th why would you use E85 gas in your lawn mower? Your tractor is not designed for E85 fuel- it may even void your warranty
For those of you that dont know what E85 fuel is, its a term that refers to high-level ethanol-gasoline blends containing 51%-83% ethanol, depending on geography and season. It can be used in flexible fuel vehicles, a John Deere 300 and its kawasaki engine is definitely not a FFV.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
2015 Ford Taurus CAR (A51694)
2015 Ford Taurus...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
