Wyobuckaroo
Platinum Member
Millet..
What I have seen with a homemade log splitter is to start off working backwards. To explain, a given splitting cylinder with a given cycle time takes X amount of gallons per hour. Then you work backwards to the size pump you need for that gph, then to the PTO or engine horse power required to run that pump.
To me, the combination of other motors you want to run is another figure to blend into the equation to determine pump size, and power requirement. You see a trend here on how to work out the math.
I'm going to guess the conveyor will run constantly with a small power requirement. The saw, and log advance will run intermittently, not necessarily at the same time as the splitting ram under full load. With these details in mind that should let you size and run a pump not that much bigger than minimum for the biggest load, being the splitting ram.
My 5 cents of experience and opinion.
