PTO run pump with spray gun
   / PTO run pump with spray gun #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
Gents
I知 plannng on building a PTO powered water spray gun. I already have a 8 foot trailer that has a 200 gal water tote attached to it. I planning on burning some large pastures this winter and want to build a fire fighting water rig. I just never messed with a PTO water pump. Can anybody provide a plumbing schematic? Do I need a pressure gauge? Will probably also make this a brush/weed chemical rig...
Thanks
   / PTO run pump with spray gun #2
Most pumps that are PTO operated , that Do Not cost a small fortune , are capable of doing what you are asking but with the understanding that they are Not Draft capable , or at least very limited in drafting , Thus your tank outlet will need to be higher than the pump .
GPM , ( Gallons per minute ) can be increased by $$ spent on pump , but then again , Not Necessarily .
152C Hypro 6 Roller Pump Cast Iron | Roller Pumps | Water Pumps | www.surpluscenter.com
6 roller pump with 33 GPM at 540 pto rpm's . 150 PSI max pressure , Which shooting out a hose for fire suppresion is more than enough for a single person .
These 2 do not have the flow in gpm's but may ?? get more pressure :
65-C Hypro 6 Roller Pump Cast Iron | Roller Pumps | Water Pumps | www.surpluscenter.com
756-C Hypro 8 Roller Pump Cast Iron | Roller Pumps | Agricultural Pumps | Water Pumps | www.surpluscenter.com
Basically from tank to pump then pump to what ever your feeding be it a hose reel for suppression or a sprayer system . Don't see the need for a pressure guage on a supression system , since it is a basic system , but for sprayer system , the guage would be some were between pump and nozzles , in case pressure needed to be adjusted with a regulator or other device , ( maybe not enough nozzles or the opposite m to many nozzles ) .
Fred H.
Thanks for the info gents... Everything makes good sense.. Ill have to check the level of the underside tank fitting compared to the PTO pump placement. I’m thinking it will be about the same or lower. Will I have to raise the tank on the trailer? When the pump is pumping and your not spraying, what keeps you from blowing the lines?
   / PTO run pump with spray gun #5
When plumbing the pump you will have a supply line from the tank to the pump and a return line from the pump to the tank.
In the return line you need a tee and 2 gate valves. One valve going to the tank, which regulates your hose pressure and keeps from blowing up the pump. The other valve goes on the hose connection of the tee.
   / PTO run pump with spray gun #7
You tank outlet won’t necessarily need to be above the pump but the water level will need to be for it to prime easily. I have pumped out of drums sitting beside the tractor. Water level was above the pump to begin with but eventually was below the pump and never had any issues.
   / PTO run pump with spray gun #8
Here's how mine is plumbed. Pretty crude drawing, but maybe you get the idea.
   / PTO run pump with spray gun #9
Cheaper and better to get one of gas powered 1" pumps from Northern Hydraulic for around $220.
   / PTO run pump with spray gun #10
I dunno, there is merit not having to maintain another small engine. Especially with ethanol gas these days.
2006 TRANSCRAFT 48X102 SPREAD AXLE FLATBED (A58214)
2006 TRANSCRAFT...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
UNUSED AGT INDUSTRIAL 40 GALLON AIR COMPRESSOR (A58376)
UNUSED AGT...
206320 (A57192)
206320 (A57192)
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58216)
2016 KOMATSU...
