PTO shaft damage on a spreader. Why did this happen?
   / PTO shaft damage on a spreader. Why did this happen? #11
I've got a typical cone gravity spreader. It isn't super cheap and seems well made and but I can say for sure that the PTO shaft is the most robust thing on it. In other words, if something bound it up, a lot of things would brake and bend before the PTO shaft would twist. And while I wouldn't recommend engaging the PTO at high RPMs the spreader is 'free wheeling' so to speak and the spinning parts have almost no mass to them, certainly not enough inertial resistance to twist a PTO shaft. Sounds to me like his came with a twist in it.
   / PTO shaft damage on a spreader. Why did this happen? #12
Perhaps your friend had it lifted up too high (the telescoping shaft would be extended) when he engaged the PTO. That combined with high initial RPM might have done it.
Terry
   / PTO shaft damage on a spreader. Why did this happen? #13
I have a Herd spreader that I use to spread sand on the driveway in wintertime. It has the same PTO shaft you're talking about, it's almost square but it's actually rectangle. While I don't engage the PTO at high speeds and I ease the clutch to avoid shock it still has to spin the agitator buried in sand. I've never had an issue with like what you're talking about. Is it possible that the shaft wasn't hardened?
   / PTO shaft damage on a spreader. Why did this happen? #14
I too like N80 have a middle of the road cone spreader and feel that the PTO driveline is the heaviest built part on the spreader. I think it would rip the gearbox apart before damaging the driveline but there might be ways using the 3 point to cause some problems although shaft twist is still hard to imagine. Since I have a hydraulic top link I make sure my spreader is vertical and the PTO driveline is close to level before engaging the PTO.
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A52748)
COOPER LIGHTING...
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
90018 (A48082)
90018 (A48082)
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
