PTO shaft engagement
   / PTO shaft engagement #11
as always learning something new.... I have a very short overlap it workable but never thought about using a different set of 3 pt lower arms and top link., sure would have made life easier if I had. I converted the 18 spline FL850 Kubota tiller to the normal 6 spline 1 3/8 found a adapter on line. I had to toss the Kubota slip clutch and used one from TSC line of PTO etc...
So my overlap is only 4 inches...if I had used a different set of lowers, could have made it a full 6, oh well., next project looking for longer lower arms at farms auctions.
   / PTO shaft engagement #12
Highbeam said:
Rather than use the adapter wouldn't it be wise to just order a new PTO shaft?
Yes. But in some cases that's just downright expensive. Example: I added Cat 2 PEC to my 45 horse. Doing so effectively extended the lower lift arms by nearly 4 inches. That in effect made ALL my PTO shafts too short by 4 inches. Instead of buying half a dozen new shafts, I got a 4 inch PTO adapter.
//greg//
   / PTO shaft engagement #13
flusher: you are far braver than I. No way would I have all that spinning behind me (ORC and SlipClutch) without a guard. Don't you worry about what could happen if any of it failed during use? It gives me the willies just thinking about it...
   / PTO shaft engagement #14
It's a rototiller, so the pto shaft rpm is pretty low (200-250 max).
And I have my backside covered with that expanded metal safety screen attached to the ROPS
I'm more concerned about stuff flying in my direction from my brush hog. That's why the screen is there.
   / PTO shaft engagement #15
I'm wondering if you could have reversed the hookup.. IE.. slip clutch to tractor pto stub, and then telescoping shaft to the tiller.. thus eliminating the extender and buying you a few more inches of overlap.
while the vast amjority of slip clutch setups i see are at he implement side.. I have seen some oem setups with a torque limiter on the pto stub side..
soundguy
flusher said:
Here is the hookup to attach my rototiller to the Kubota B7510HST
The overlap on the pto shaft sections is not more than 5 inches. It works fine.
Had to cut a shaft that I bought at TSC to get it to fit between the tractor and the slip clutch (the tiller doesn't have shear bolts, hence the slip clutch).
Don't need an overruning clutch since this is an HST tractor.
Needed to add that pto shaft extender onto the tiller to keep the slip clutch from rubbing on the tiller sheet metal.
This made the drive train too long for the 26" lower arms that are standard on the 7510. Had to use the 35" arms from my 1964 MF-135 diesel to get enough room to handle all that drive train stuff.
   / PTO shaft engagement #16
soundguy
Don't see why you couldn't do this.
   / PTO shaft engagement #17
don't think the slip clutch will clear the PTO guard on the tractor side...will not on the BX 24...just tried it...darn...was hoping it might!
Hey, I like the seat back guard...darn you all another new project!:D :D
   / PTO shaft engagement #18
I missed the screen. That is a great idea, and if you made it yourself you did a great job...
   / PTO shaft engagement #19
Soundguy said:
Good point about more parts to wear, if the ORC properties are not needed.
I can think of one situation where the ORC may not be needed.. but might be usefull.. like in a situation with a large flywheel load on the pto, where you might want to save your pto brake.. IE.. a large mower or a chipper.. with an ORC.. it could spin down instead of havinghe pto brake grind it down to a stop.. etc..
soundguy
Im not familiar with a need for PTO braking. Why are they employed on some systems?
larry
   / PTO shaft engagement #20
Hmm.. maybee for safey? Dunno really.
Perhaps just to arrest movement of spinning blades .. etc..
On some models.. if the pto brake is bad.. the pto will freewheel.. i see that as a bad thing as it may grab grass.. etc.. and perhaps eat the seal up..
soundguy
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
