PTO Shaft lube ideas ????
   / PTO Shaft lube ideas ???? #11
I only have a rear PTO shaft for my tiller. After it sits for 6 months it get's stiff with grease on it. I give it a shot of WD 40. That thins the grease so it slied nice. It is still protected form the weather with grease.
   / PTO Shaft lube ideas ???? #12
Eddie might have the same problem that a lot of us have. When you use different PTO driven attachments, the male on the rear of the tractor is going to stop at a different position after use. The male is then no longer in the "line up" position from the previous implement. Don't you have to rotate the shaft to line up when you go to reattach the first mower? This is the biggest struggle I have. When I get the splines in the correct alignment, they always slide on very easily.
   / PTO Shaft lube ideas ???? #13
Eddie
Could it be the grease seals the rod in the bore and air cant get in?
Try a 1/8" hole in the back of the female slide near the yoke to brake vacuume.
tom
   / PTO Shaft lube ideas ???? #14
That's what big screwdrivers or tire irons are for... aligning yokes! ( they inexplicably also work for large screws and tires! )
soundguy
   / PTO Shaft lube ideas ???? #15
   / PTO Shaft lube ideas ???? #16
That's what I use. (The screwdriver). The crescent is a great idea!
   / PTO Shaft lube ideas ???? #17
Neat wrench.. thanks for posting the link!
soundguy
DRILLING CABINET (A50854)
DRILLING CABINET...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
