PTO Shaft question
   / PTO Shaft question #1
topshop
Bronze Member
Northeastern Michigan
I have a NH TC34DA and am about to buy a King Kutter 60-inch tiller. Does anyone know if I will have to shorten the PTO shaft on the tiller?
   / PTO Shaft question #2
When you hook it up, you will know.
Bob
   / PTO Shaft question #3
Bob
If you can't hook it up, you will know for sure. Seriously, there should be a minimum of 6" of overlap at the longest length and sufficient clearance to connect and disconnect the shaft at the closest point.
   / PTO Shaft question #4
You will definitely have to shorten it. I bought that same tiller for my tc33da much the same tractor. Do not forget to put the oil in the tiller,top and side filler holes,it did not take as much as the instruction book said .
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
