PTO Shaft Release Collar
/ PTO Shaft Release Collar #1
rocknrod
Hico, TX
LS Tractor, Model R4010
I have a Howse shredder/mower. The PTO shaft on the tractor end has a release collar you turn to install and remove the shaft.
That collar has a crack in it. It still works. I want to replace the collar - Does anyone know where to buy that part?
It's a plastic collar by the way.
Thank you for your help on this.
/ PTO Shaft Release Collar #2
The plastic doesn't carry any load. It just something to grip to release the collar, isn't it?
If you want to replace the collar check with the manuafacturer to see if it is replaceable, i.e. is there is separate part number for the plastic cover.
Otherwise, you'll have to replace the whole u-joint assembly.
Yes I just want to replace the collar.
Does anyone know where to buy them?
FYI - I found out it's called a Twist Collar. And they make repair kits sold online at various places. Just needed to get the nomenclature right.
/ PTO Shaft Release Collar #6
Can you tell me what photo 'site' you use to download your pics that shows the 'click to enlarge' banner at the top of each pic?
Thx,
CM
{P.S. I know its not on topic- but your question was answered already so its not like I'm hijacking your thread}.:)
/ PTO Shaft Release Collar #8
Thanks!:thumbsup:
/ PTO Shaft Release Collar #9
howse has a breakdown/listing int he parts manual.
soundguy
/ PTO Shaft Release Collar #10
hate to ask this but what is difference between "collar" and "Synch" shift option on a JD
/ PTO Shaft Release Collar #11
i've always called a shifter on the column a collar or column shifter.. not sure that address's yer question though.
sync shift makes me thing synchronised.. etc..
soundguy
So I received the part and put it on. Works.:thumbsup:
/ PTO Shaft Release Collar #13
I need this same part now but I can't find it anywhere. Did you order it from Agri Supply? They claim not to have it and it doesn't show up on their site anymore.
/ PTO Shaft Release Collar #16
Hey thanks for looking. I did actually find that one on efarmtools.com but I have a huge problem paying $50 for a $6 part that's already broken twice on me on two different implements. I could buy a new yoke with a more traditional attachment method (made of metal) for less that. I guess I'll have to go that way as it seems Braber had the same notion and just stopped making them. So I guess they're a collectors item now!
I do not like fighting equipment. So I pay the price either way.
/ PTO Shaft Release Collar #18
I gave up on the one on our Howse bushhog and when you pull all the plastic off it becomes just a pin style, I just push the pin to remove and make sure it is seated when installing.
Brent
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A61574)
1999 22ft Sea Ray...
2021 Dodge Charger AWD Sedan (A61574)
2021 Dodge Charger...
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
