Pto shaft spinning when pto shaft is disengaged
   / Pto shaft spinning when pto shaft is disengaged #1
Skylar3788
2012 john deere 8285r
We have a 2012 jd 8285r the pto shaft is still turning when pto is not in engaged. Any reason what might be causing this?
   / Pto shaft spinning when pto shaft is disengaged #2
Does your pto have a shaft brake? if it does, it is generally pressure actuated and so whatever supplies the pressure isn't supplying it and the sloshing of oil in the reservoir (i.e. the rear axle housing) can cause it to turn.
I am assuming it does we got it last year it has an electronic switch to turn it on and off also we can stop the shaft from turning with an object and as we increase the rpm it seems to slow the shaft down and eventually stop spinning
   / Pto shaft spinning when pto shaft is disengaged #4
Sounds like it might need a clutch or control linkage adjustment.
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
19200 (A50324)
19200 (A50324)
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
