PTO Shredder / Chipper Review MacKissic TPH185
   / PTO Shredder / Chipper Review MacKissic TPH185 #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
Review of MacKissic Mighty Mac TPH185 PTO Shredder/Chipper. I am doing a fairly extensive review since there is not a lot out there on PTO shredder/chippers, particularly the MacKissic.
I purchased it new this summer. It is rated to shred up to 1.5” diameter through the shredder and chip up to 4.5” diameter through the chipper. I sold my newer Woodmaxx WM-8M chipper because I wanted the PTO shredder capacity. The Woodmaxx was a very good chipper. I also had a 338cc Champion self-powered chipper shredder but wanted substantially more shredding capacity which the MacKissic provided. Shredding is now so much faster! The Champion was also heavy and awkward to move around the property.
My land is predominantly forested with large conifers and some oaks. Each year they drop substantial amounts of needles, twigs, and branches. For a number of years I hauled large loads to the dump or burned which robbed the ground of the natural duff which acts as mulch as well as replenishing the soil. More recently I have been spreading the chips and shreds. They also provide a nice ground cover.
I am very pleased with the MacKissic. It is solidly built without excess complexity. After many hours use there has been no problems. The shredding capacity is way beyond the Champion. I have chipped over 3” trees without a problem though it is slower than the Woodmaxx and the infeed opening is not as large. This works fine since I generally use over 3” for firewood.
The MacKissic is not set up to use a full 3 point quick hitch but does work fine with Pat’s Easy Change system though the included shaft ended up being too short which I solved with a Double HH 23556 Extension Adapter . MacKissic normally stocks a longer PTO shaft but was unable to get them with the Covid supply issues.
The MacKissic does not have an upper discharge chute and discharges the chips onto the ground. I capture the debris with Shappell ice fishing type sleds. A JS1 on the side and a JSR Jet Sled Junior underneath. These slide fairly easily on the ground and makes it easy to distribute the chips. I use them a fair amount to haul debris and materials around as well. You can just discharge onto the ground but I found it inconvenient to have to stop and clear the buildup. If you want it to go directly into your trailer or pickup this is not for you.
The MacKissic comes with a 1.5” screen which the output exits through. There are two rows of openings, perhaps 4” wide by 1.5” tall. It did not mulch pine needles very much and frequently threw out elongated branch pieces. I replaced it with a ¾” round holes from MacKissic which worked much better. Perhaps even shredded finer than needed. The smaller holes did not slow the output much though my PTO HP is about 46. Not sure what it would be like with lower HP. They also had a 1.25” diameter round hole screen which I would like to try as well but the screens are expensive. If I were buying the shredder/chipper again I would probably see if I could get it with the 1.25” screen. Am not sure why they sell it with the 1.5” since I would think most people ordering a shredder/chipper would want the output to be more mulchy.
I also considered a Wallenstein BXM32 shredder chipper but it was about $1500 more expensive and had smaller chipping and shredding capacities. It did have a standard upper discharge chute.
It is useful to note that the MacKissic site dealer locater does not list many of their dealers. I found mine by contacting their west coast distributor.
Overall, I am very satisfied with the MacKissic and certainly recommend it.
   / PTO Shredder / Chipper Review MacKissic TPH185 #2
I had a TPH-122 for 16 years. Great chipper/shredder. Easy to work on. Rotated the shredder hammers 3 times and replaced 4th time around (have 4 corners: the lead one gets rounded). Had a spare chipper blade and rotated the two many times, e.g. used one while other was sharpened in machine shop. My source of leaves dried up; so, bought a WM WC46 to replace it. Also needed one that didn't require a very high lift to get stuff into the chipper. The WC46 has hydraulic feed and has a horizontal input chute.
   / PTO Shredder / Chipper Review MacKissic TPH185 #3
Thanks for the detailed review. I think the mix of chipping vs shredding that one does and the kinds of material processed will greatly affect the usefulness of each machine.
I have both a TPH185 and a Woodmaxx 8H. When I got the Woodmaxx I stopped using the MacKissick except once a year to shred leaves. The vast majority of my work is chipping and for that the Woodmaxx is much better. Nearly all the shredding I did with the MacKissick was to deal with small material that was safer or easier to shred. I can feed that through the Woodmaxx with no problem and it's much easier to do that than to get it down the MacKissick's shredder let alone the chipper. It's just leaves that won't go in the the Woodmaxx.
Eric, I agree about the differences with the MacKissic chipper and the Woodmaxx, even with the 8M (not hydraulic) I had. With the Woodmaxx it was only necessary to push the branch or tree in far enough for the infeed wheel grip it and pull it in. The MacKissic absent of an infeed wheel usually requires more holding and pushing which is often uncomfortable since the branch vibrates and jumps around.Having the xlnt shredder more than makes up for that.
The shredder on the other hand is xlnt at pulling material in. It's so fast at times you need to be careful. The speed and volume makes shredding a pleasure. Further, since it shreds branches up to 1.5" I don't have as much I need to run through the chipper. The instructions actually say single branches or a combination of branches up to 1.5". I definitely have not had a problem putting larger combinations over 1.5".
I figured when I sold the 8M that if I had any high volume chipping needs I would rent a large commercial chipper. I did this for a property I was prepping for fire safety last year after trying it with the 8M and there was a world of difference. Not criticizing the Woodmaxx, the commercial ones just function at a whole other level.
Eric, in your MacKissic do you have the 1.5" onlong hole screen? Do you find it shreds small enough for your needs?
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
