PTO slip clutch - bad or?
   / PTO slip clutch - bad or? #1
DieselBound
Elite Member
Arlington, WA
Kubota B7800; Kioti NX5510HC
I'd worried that the slip clutch on my PTO shaft (bought new a few years ago- Bare Co.) for my bush hog wasn't slipping: I cannot recall whether I'd previously taken this one apart and cleaned it up or whether it was the one that I'd had when I originally bought the bush hog (used - the original shaft didn't last very long- it was crap when I got it). I loosened it up and ran for quite some time to ensure it was actually able to slip and not froze up. I saw (marks I'd made) that I'd gotten it to slip. At one point, I think before I decided to set the spring lengths proper, I saw some black smoke poof out. Once adjusted to "spec" I ran it for quite a while with no apparent signs of problems. And then today... While mowing in some very tall, heavy and wet grass I saw it start to smoke: saw white smoke. I backed off and decided to just finish up mowing in some much shorter stuff, but I saw that it was still struggling, still wanting to smoke, so I decided to call it a day. Though hot, I could see no obvious signs of overheating or missing chunks of the clutch plate. Before taking it apart I'm wondering if I can just tighten it up. Here's why I am considering doing so (I know it's not something that you really should do)...
I have TWO different specs on the spring length. The PTO shaft manufacturer (Bare Co.) says 1.18", which is what I set the springs to. Bandioli and Paves (the style or the actual manufacturer of the slip clutch?) says that it should be 1.10". Not sure if tightening 0.08" would make much difference.
Perhaps things are glazed and I might be able to clean up? Yes, I probably should just take it apart, but I'm kind of curious as to what all sorts of problems these things can have: this is the only one I have (or have had).
   / PTO slip clutch - bad or? #2
Sounds to me like your adjustment is pretty close. Add an eighth of a turn to each bolt and see if the slipping improves. I regard the spec provided by the slip clutch manufacturer as a starting point. Good luck!
   / PTO slip clutch - bad or? #3
There's NO known adjustment for YOUR tractor! Tighten it up until it stops slipping.
Also, every time you slip it, you are making the plate in it thinner, so you have to compensate for that...
SR
I was concerned that at the least I might have glazed it. That it seemed to easily slip on lesser grass, once out of the ugly stuff (a good 6' to 7' tall), I got concerned that it might be toast: I believe that I did catch it early in which case I'd like to think that I couldn't have done any real damage to it.
   / PTO slip clutch - bad or? #5
Here is how I set mine after a rebuild, new clutch disc's. Tractor at idle, someone else in cab to turn PTO ON. Upon engagement I adjusted till my blades came upto speed in about one revolution of slip. Went out and chopped down a bunch of pine saplings 3" and under worked great.
   / PTO slip clutch - bad or? #7
I prefer the bolt. On the stuff I buy with a clutch, at the start of the season, I measure the thread length and then back off the bolts till it slips. Let it slip at low PTO speed for a couple of minutes. Retighten the bolts to the previous thread length. If it slips when encountering heavy material, tighten bolts a bit at a time till it stops. Other thing is that I keep them under a shed. That way condensation moisture generated rust is all I have to scrape off.
   / PTO slip clutch - bad or? #8
I'd take a blk. marker and put a line on each nut. (so you can see it go around) Then tighten them all 1/2 to one turn each.
Run it, and if it still slips too easy, go another round tighter on each nut...
SR
   / PTO slip clutch - bad or? #9
SR
I am able to use a ratchet/socket on my slip clutch nuts. So I put a ring of masking tape on the socket, then use the marker to mark a line. Then I can tell how far I turn the nut. I do not have to remove the socket to see a mark on the nut and it I "ratchet" I do not lose count if I were just trying to count turns/partial turns of the ratchet.
   / PTO slip clutch - bad or? #10
I assume once the friction disc is glazed it's ruined? Is that correct? Or can it be saved?
2016 INTERNTATIONAL 4300  BOX TRUCK (A50046)
2016...
2019 MACK PINNACLE (A48992)
2019 MACK PINNACLE...
2005 FORD F-250 (A46684)
2005 FORD F-250...
275 GAL HORIZANTAL SKID TANK (A48992)
275 GAL HORIZANTAL...
2015 FREIGHTLINER CASCADIA(INOPERABLE) (A48992)
2015 FREIGHTLINER...
Ryobi Sliding Miter Saw (A48837)
Ryobi Sliding...
