PTO Slip Clutch Installation
   / PTO Slip Clutch Installation #1
SimS
Rutledge, GA
Kubota L3710DT, Case 1845C, Takeuchi TB015
After replacing many shear bolts on my 5' Bush Hog I have decided to install a slip clutch. I need to know what grade of bolts I should use to attach the clutch. Some folks say "Just slap on Grade 8 and go for it". I'm thinking that I will probably go with Grade 5 "just in case". Also, what is the preferred way of adjusting the clutch? I read a Bush Hog manual that says that the clutch should be adjusted periodically by loosen the bolts and letting it slip for 2-3 seconds and then adjusting it to the proper spring length. My question is how does the same spring length dimension account for clutch plate wear? I'm assuming that you must adjust to compensate for wear. Any advice or experience is appreciated. Thanks.
SS
   / PTO Slip Clutch Installation #2
Adjusting to spring length keeps the pressure at a predetermined value. If you are going tjo adapt a slipclutch jto the shaft that has the shear bolt, I would bet that you will be shearing bolts for a while until you get the clutch set at the right limits. DO NOT PUT GRADE 8 BOLTS IN. Go with the ones that the manual calls for. In hard pulling you will probably smoke the clutch some to let you know to back off, but better that than a destroyed gear box. Once you have determined that you have the clutch adjusted to the limits of the shear, measure the springs and tuck your findings in your manual for future reference.
I used to have a mower with the shear system, I couldn't haul enough bolts in the tool box. I have since went to a heavier hog with the clutches. Have replaced the clutches a few times, but then I do some extreme mowing.
   / PTO Slip Clutch Installation #3
The slip clutch is easy to damage if you aren't watchful ... after you install the clutch or after it has sit idle for a long time, you need to adjust it so that it will slip just a little when you start to use it ... this is so the clutch surfaces get the grease, rust and what ever cleaned out ... just let the clutch slip for a few rpm .. not many ... then tighten the adjustment so that in normal cutting it is not sliping ... but (this is the part of the instruction I always disliked because it means trial and error to get it right), not so tight that it will not slip when you hit that immovable object ... I would hope that you got instruction about this with your slip clutch when you bought it ... if the clutch is mounted using the shear pin bolt to secure it to the shaft then one or the other is going to have to be "weaker" of the two and you want that to be the slip clutch ... If you have mutli springs pull them down to the same height all around ... If you have a single "Big Nut" used for the adjustment it's easier to adjust .. my experince with shear pins they seem to shear awful easy and even if they don't shear for a while they take a beating and progressively get weaker then shear anyway .. They don't give those clutch disk away and they aren't cheap ... but I sure got tired of replacing pins ...
   / PTO Slip Clutch Installation #4
I have a slip clutch on my cutter but there's no adjustment.
Billy
   / PTO Slip Clutch Installation #5
Interesting, how do you account for the wear of the clutch. When the implement hits something and causes the clutch to slip I would think there would be wear of the fiber disk. Or does yours have fiber disk or something else?
Leo
   / PTO Slip Clutch Installation #6
It has the disks. I looked through the whole owner's manual and it says nothing about an adjustment. The clutch is on a JD 616 cutter. The manual does show how to disassemble and inspect it. It says if the disks are glazed (shiny and glossy), replace but mention of an adjustment. So, I don't know.
Billy
   / PTO Slip Clutch Installation #7
the fiber discs do wear and I adjust up as needed. When it starts to slip too easily just take a turn or two on the pressure springs.
   / PTO Slip Clutch Installation #8
I dunno .... it may be just me ... but everytime I've snapped a shear pin .... and let me tell you, Tractor Supply has sold me a few! ... it has been because I got WAY too aggressive. I've never broken one from any problem with the deck or power ... just from trying to chop down too much brush at one time (say four 2 inch trees instead of one at a time). Same with the auger ... only time I broke a shear pin is when my foot slipped and I moved the tractor while boring.
So I'd have to ask ... are you sure that your deck is big/strong enough and you're not trying to push it too hard? I'd be a shame to go to all the effort of buying and installing a clutch when it didn't solve the problem.
   / PTO Slip Clutch Installation #9
Dumb question time:
Does the JD4300 have a slip clutch built in to the PTO system? I've heard of adding them, but I think the ones I've heard of are a different beast altogether.. they, for example, let the finish blade spin down slowly rather than stopping dead when you disengage the PTO. I think we're talking different things here.. things to protect implements and the PTO drive mechanism..
The ones I've heard of are often described as helping to attach implements because they turn freely in one direction. This isn't what you're refering to here, right?
Bob
   / PTO Slip Clutch Installation #10
Bob,
You're not thinking about overrunning clutches are you?
We use them on old gear drives so when you want to stop while brush hogging the momentum from the spinning blades won't back drive the tractor through the PTO geartrain. An added bonus is that they freewheel in the direction of rotation so you can rotate by hand the PTO to connect to the impliment.
FWIW,
Michael
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2001 Nissan Pathfinder SE SUV (A55853)
2001 Nissan...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
Kubota RTV-X900...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
