PTO Stump Grinder
/ PTO Stump Grinder #1
cheesehead
Central Florida
Kubota L3130F-HST
What experience is out there on PTO stump grinders? The land I'm clearing has very dense tree growth and I've been renting a grinder that will drive me to the poor house if I keep growing in that direction ($750/week). A BH is probably not the right approach as disposal of the hundreds to stumps would be a major issue (can't legally /forums/images/graemlins/shocked.gif burn where I'm at). Any help would be appreciated.
/ PTO Stump Grinder #2
What are you going to use the cleared land for? In my area of Michigan we can haul our stumps to the landfill and dump them for free because of the no stump burning law.
At $750 a week, depending on how many weeks you are going to rent the grinder, you may be able to purchase a BH and also have the stumps hauled away for less $$.
Farwell
/ PTO Stump Grinder #3
in three years you should be able to kick them over. I am dealing with 60 acres of clearcut and I finally listened to my old fashioned neighbors, just let them rot. In2 years your plow should rip right throuth them.
/ PTO Stump Grinder #4
Nobody has actually answered your question yet, and I won't either. But I will respond. I considered this a couple years ago and even started or resurrected a thread just like this. I don't think anyone has ever bought one. At least that hangs out here. I decided against it, went the backhoe route. If I were to buy one I think, and I believe it was the consensus here, that it would be better to get a used dedicated one than a tractor attachment.
/ PTO Stump Grinder #5
The ones I have investigated took more power than your machine makes and were very expensive. When you're done, you have a bunch of underground organic pockets that will settle and cause your smooth ground to become cratered.
This is much like the PTO trencher threads. Nobody that has looked into it ever gets one. Price, limited use, and less than ideal results. Plus the fact that a backhoe is an alternative help me steer you away.
/ PTO Stump Grinder #6
Over the course of the summer my neighbor had 30 acres of clearcut hardwood land ground up with a hottop reclaiming machine. Like a giant rototiller that ate the stumps (4"-30") and left a seed bed behind. They worked 3-5 acre plots when they had no other work. Ground the stumps to chips & worked them into the soil. They went down 8". Horse pasture, nicer than my lawn.
/ PTO Stump Grinder
Thank you for the replies. In the end the land will become a christmas tree farm so it will see regular clearing and leveling. As to taking the stumps to the landfill, our landfill charges $35/ton for tree and yard refuse. It doesn't take too long to get to a ton of stumps.
/ PTO Stump Grinder #8
I used a Stumpbuster SC-50 from Shaver mfg. on my 4400 to grind some stumps. The grinder is actually my dads. First of all, have plenty of PTO HP. I realize that a 4400 is not rated for a SC-50, but I ground some pretty large stumps with my tractor. The older the stump, the easier to grind. He ended up buying a 5510 JD. I have not used it but my brother says that it works like a champ. I am not sure if I answered your question, but my opinion is that speed of grinding is directly proportional to the amount of horsepower that you have.
/ PTO Stump Grinder
Thanks for the reply. I looked that unit up on the web and it is rated for 35 - 100 HP tractors. It does have a little brother (SC-25) for 15 - 35 HP tractors. One iten of concern is that the blade only cuts in one direction. This is where your experience would help me, how much depth can you take in a pass? The Vermeer I'm currently renting is an SC252 (25 horsepower Kohler engine) but it's limited severely by the teeth it uses that will only cut about a 1/4" per pass. It will cut in both directions which is good for this unit as the sweep is regulated to about 3" per second. I'd suspect that the return sweep is a lot faster with the Stumpbuster.
/ PTO Stump Grinder #10
Chuck
Some thoughts from my experiences raising Christmas Trees:
I thought about going with the three point type as well, but ultimately backed off because of the high cost ($5,000), and the bulky set up.
Look down the road when you begin harvesting or cutting trees. With your 4 acres, you will probably want to re-plant in the middle of the rows you have harvested. This means of course, that the stumps will now be in the middle of your tree rows, either wrecking havoc with your mowing equipment, or tripping over them if you are backpack spraying. Your size Kubota is not going to fit down the standard 60" tree row spacing,
For these reasons, I went with a Steiner tractor and stump grinder set up. It does a fabulous job on any size stump, is self propelled, and is small enough to get down the tree rows.
Ventrac makes similar units. Both units are very pricey new, but they have the same basic design for 30 years, and there are great deals on used units from private owners. Stay away from the commercial golf course and goverment units, as they tend to be abused. Search "Steiner" under "Home & Garden" on e-bay right now for a great deal on a like new stump grinder for $800. Good tractors go for as little as $1,500-$3,000.
I am in the process right now of clearing next years planting area, and grinding Christmas tree stumps in the middle of the tree rows from our choose n' cut sales this year. PM if you want for some pictures of the equipment in action.
Check out the following links for some nice equipment. Look at the tree farm mowers as well. Very sweet set ups!
Steiner Home Page
Ventrac Home Page
Bill
/ PTO Stump Grinder #11
I know this thread is quite old. I just found it, as I was searching for any input on Steiner Stump Cutters. I just bought one (cheap) from a Golf Course, sight unseen and am waiting to get it. I disagree on staying away from municipal equipment in favour of private. Governments love throwing away our money and will change parts in something they are getting rid of next week. They have departments that do only that! Not sure about Golf Courses, as I have never bought any of their used stuff. I know someone that bought a Steiner from a Course and it was A-1.
I have a Vermeer 650B, I believe, and it is a monster. Will do a six foot stump. Has a Wisconsin 60 some odd horse, 4 cylinder gaser. Came from a City Parks dept. and it's perfect. I just hate anything with a gas engine in it. I have a ton of old Elm stumps to grind and when they are done, will sell the Vermeer, to make room in my shed, and hopefuly the Steiner will work for the odd stump. That's my plan anyway.
As far as stumps rotting. Goes back to my observations of life. I have a very negative religeous name for it, which I won't go into, but basically it works like this. If you want something like an orfice to spray liquid, it will get plugged, but if you want something not to leak, the holes will only get bigger, not plug up. And with stumps, if you are using a stump for something like a table or fence post, it will rot in no time, and the other stumps that wreck your mowers, will stay like iron forever!
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2014 Ford Focus Sedan (A59231)
2014 Ford Focus...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
