PTO Tiller for BX2350
   / PTO Tiller for BX2350 #11
Thanks for the info. I've read on here where others recommend against a reverse with a BX2350. I see you have a FEL and assume that extra weight would be necessary with "Reverse" of a PTO tiller. Do you have Ag tires?
I just found a great LandPride dealer Home in Russelville , KY and will take delivery this week of their GS15 Series Grading Scraper. My sales rep is Jonathan Hodges, he's the best! I will be purchasing the tiller from him!
I run a reverse 50" Land Pride with my BX2660 using R4's; sometimes I have my FEL on and sometimes not, works well either way.
   / PTO Tiller for BX2350 #12
Do the PTO tillers usually come with the slip clutches or do yo have to buy seperate?
Just installed the Pat's Quick Hitch! Wow what a great product. manufactured right here in Kentucky about an hour from me.
I dunno- When I asked for a tiller to go with my kubota when delievered at the same time, it came with a slip clutch. I was glad to have a slip clutch. If it didnt come with a slip clutch then most likely it has a shear bolt instead.
   / PTO Tiller for BX2350 #13
Many come with the slip clutch as being optional. I haven't bought anything with a shear bolt in years. The shear bolt is more simple as the slip clutch needs occasional checking/adjustment.
   / PTO Tiller for BX2350 #14
I have used both slip clutch (own one) and a shear bolt unit. I have to say I like the slip clutch a lot better since I dont have to have a small bag of bolts to replace every so often. Where I live in the mountains, the soil is very rocky and the slip clutch has proven itself.
   / PTO Tiller for BX2350 #15
front weight probably helps. of course, four wheel drive helps, and a bit of weight on the tractor. make sure you check your front tires's pressure, as those things can take a beating w/ the tiller, i think. i have the industrial treads.
   / PTO Tiller for BX2350 #16
i love LandPride. I grew up down the road from them about 90 minutes. Great stuff.
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
RV Hitch (A50121)
RV Hitch (A50121)
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
