PTO Wood Chipper
   / PTO Wood Chipper #11
Mine looks similar to yours. Here are my mods:
1. Added swivel to exit chute (mine was fixed in one direction)
2. Replaced belt drive mechanical in-feed gear box with bidirectional hydraulic drive motor with motor speed flow control and hydraulic splitter controls
3. Replaced in-feed drive shaft with custom HD greasable yolks drive shaft
4. Modified in-feed chute to flip up design with hinges to make unit more compact for storage
5. Modified base for forklift lift points from both sides
6. Added ball hitch draw bar so I can tow a small trailer for wood chips at the same time
7. Modified exit chute with slotted holes to allow quick removal of chute for un-plugging debris
Future mods:
A. Direct drive coupling for hydraulic motor to in-feed roller - eliminates PTO shaft and adds weight to in-feed roller
B. Modify in-feed roller for vertical motion and add HDPE slider bearings, possible hydraulic actuation for up/down to eliminate springs
C. Single point greasing of all fittings. It's difficult to get at all the grease points with the current shields in place
Which chipper do you have? I壇 also be interested in pictures.
   / PTO Wood Chipper #12
Some no name Chinese junk chipper. I took a risk buying it because it was cheaper than me buying the raw materials and fabbing it up. Now Im paying the price with constant repairs and mods!
I will post some pictures when I pull it out of storage. Let me know what parts you want a closer look at and I will try and get some photos posted for you.
Another poster asked about the base. I used 6x2x1/4 tube and made a box frame a little wider than the factory base and welded it on. I cut some slots on the side so I can grab it with my forks from any side for storage. An unintended benefit of the new base is that it really stiffened up the chipper frame making it less rattley and a little quieter.
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
WESSEX CRX 180 LOT IDENTIFIER 158 (A53084)
WESSEX CRX 180 LOT...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
