Pull, semi, or 3pt 10ft rotary?
   / Pull, semi, or 3pt 10ft rotary?
Robert, I think what you said makes alot of sense. The Kodiac cutter show above seems like it would do the job and hold up well. Thanks for your reply.
   / Pull, semi, or 3pt 10ft rotary? #12
For reference--This picture is showing a picture of a HD "Agri 120" 10 ft pull type with chains--Ken Sweet
Sweet Farm Equipment Co.
   / Pull, semi, or 3pt 10ft rotary? #13
I have a JD 5220 2 whl dr with liquid filled tires and FEL which I use to cut pastures (I have never had a reason to take it off) etc. The land is fairly flat but does have some small hills. I use a 3ph 10' rotary mower which works just fine. I was concerned about being able to back into some areas with a towed mower. I also was concerned about the weight (light) of my tractor but not it's power. So far, I have not regretted my decision and have been very pleased with the results. I have cut grass and weeds (Some Dog Fennel included) that there so high I could not see well in large sections of the fields with not much problem (just slowed down by dropping a gear or so) . I keep my PTO speed at the rated speed which I consider important with any PTO driven implement. The ground speed for most of the fields when I have missed cutting for a while (most grass about waist high and heavy) was about 4 – 8 Miles per hour. (except where wild hogs have screwed up the area, then you must slowly work your way around … these places can be a great surprise). Because this worked for me does not mean that it will work for you … I think the dealers’ recommendation is, for the most part, based on many factors that may be in your favor rather than his. I have dealt with some good dealers and I may be just lucky in that respect. Any way for what it may be worth ….
Leo
   / Pull, semi, or 3pt 10ft rotary? #14
Guess where I live, a corn stalk chopper can knock down all kinds of pasture brush & grass. They are built very heavy, & 12' (4 row wide) models are out of style, so used go for $400-600, and as heavy as they are built, would last a lifetime. I can pull my 12' with a 40 hp tractor in stalks, altho that is a workout, I should think his tractor would pull it in grass; and should he need any brush trimmed down, no problem. However, if not in an agricultural location, then you wouldn't be able to find such a thing. /forums/images/graemlins/smile.gif
--->Paul
   / Pull, semi, or 3pt 10ft rotary? #15
I guess I don't know. I have never seen one used in anything but cornstalks. I don't think it would work in place of a flail mower since that gives a finished cut job. Might work in weeds but in brush I would wonder. I will talk with my neighbor and see if they ever use thiers in anything other then cornstalks. Have fun.
   / Pull, semi, or 3pt 10ft rotary? #16
Hi Paul--Most of these that I have seen in Ky are belt drive units--are there used gearbox models out there in the price range you mention?--Ken Sweet
   / Pull, semi, or 3pt 10ft rotary? #17
I am also interested in knowing if a used corn stalk chopper would do a decent job of pasture trimming - not looking for a finish cut but would like something more than 5' feet wide that could be run from MF 35 tractor - 38 HP.
Bob
Mr. Sweet, could you tell me how your unit is different from the Kodiac, specs, and what is the price.
   / Pull, semi, or 3pt 10ft rotary? #19
Kodiak 10' Cutter
-Lamanated tale wheels with bearings not bushings
-3 Gearboxes- 90 HP
-HD CV PTO and clutch
-7 ga. Deck thickness with reinforcements
-8" HD Channell Sidewalls
-5/8" thick stump jumper
-HD skid shoes
-self-leveling deck
-2-12" cutting height
-1850 LBS
   / Pull, semi, or 3pt 10ft rotary? #20
Hi--Hope you got my private email in regard to pricing, features and shipping--Looks like ours has more features and specs out better than the Kodiac--Ken Sweet
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
(2) 48" HANG ON FORKS (A54756)
(2) 48" HANG ON...
CUSHMAN HAULER PRO ELECTRIC GOLF CART (A54756)
CUSHMAN HAULER PRO...
2016 CHEVROLET 2500 TRUCK (A54756)
2016 CHEVROLET...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
