Pull type box blade with tilt axle??
   / Pull type box blade with tilt axle??
Yes I would agree in small spaces it would not work very well I have a 3pt box to off set those times. I have a few bigger projects coming up that a drag style would be nice to have plus I may use it to keep the drive up until I built a land plane for that. Really trying to decide if the tilt is worth getting or just go with a standard rear non tilt axle design.
   / Pull type box blade with tilt axle?? #12
Get a tilt, even if you just have a ratchet adjuster on it instead of a cylinder.
If you buy non-adjustable, for those rare times you may want a tilt, add a skid shoe to lift the high side a bit. Another way is to have a larger or smaller wheel to swap into position as needed.
Bruce
That may just be what I do, least I would have the ability if I decided to use it.
   / Pull type box blade with tilt axle?? #14
Dont forget you would need 2 sets rear remotes if you go hyd on tilt and lift.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
iDrive TDS-2010H...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
iDrive TDS-2010H...
