Pull type rotary cutter question
   / Pull type rotary cutter question #1
bx24
Platinum Member
Indiana
I was looking at a pull type rotary cutter and never having used anything besides a traditional 3pt style, I was wondering if anyone could help.
When using the 3pt style, the PTO shaft stays in in a straight line behind the tractor. I like the idea of a pull type mower, but does it cause any problems when you are turning with the PTO running or does the u-joints pivot without a problem.
I see the highway mowers all the time doing this so I guess it would not be a problem, but it just seems like it would be a little bit of an issue.
If anyone has any other comments about pull types, please don't hesistate to share.
Paul
   / Pull type rotary cutter question #2
The u-joints pivot without an issue. Not a problem. If you turn, or back-up and "buckle" the mower (like a trailer) so that the PTO is at something like 90* you'll get some vibration and clattering. Usually they'll turn to a maximum angle of 80 degrees though. Often the rate-limiting factor is that the driveline shaft sleeve may hit the lift arms on the 3-pt hitch first. Some people actually take those off. Unfortunately I only have experience with a pull-type mower and not a lift type. I have a 10' pull-type rotary cutter.
Thanks Glowplug ... that answers my question. Similiar to the other bx using a 5' bush hog, since the weight factor of the cutter is right at the practical limits of the tractor ... I am leaning towards making it into a pull type.
   / Pull type rotary cutter question #4
Hi BX24,
I have always used a pull type cutter to mow some pasture, a lane between fields, and water-ways. In the past I have used an IH "M" tractor (no live PTO). Recently I bought an L3830 (still have the "M"), and thought I would try the pull type cutter on the new Kubota. It worked great. I put a draw-bar between the two lower links to pull the mower, and adjust the height. The one thing you must watch is how high you lift the draw-bar. You are limited by the PTO shaft which is ABOVE your mower hitch.
Turning is no problem for the PTO shaft, as mentioned by Glowplug. Backing is just like with a trailer, don't cut real short.
The live PTO on the L3830 made it very nice to use. I set the PTO rpm at just above 500, and then controlled ground speed with the GST. In rougher spots I just shift down, and in smooth areas I ran in 8th gear with ease.
I have considered a 3pt. mower in the past, and might try one some day, but for now the pull type is just fine.
KW
RCcar Industry RC-G4.0 Golf Cart (A43476)
RCcar Industry...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2017 Chevrolet...
2017 FORD E350 16FT BOX TRUCK (A45678)
2017 FORD E350...
2011 Chevrolet Malibu Sedan (A46684)
2011 Chevrolet...
2019 GMC Savana (A47307)
2019 GMC Savana...
2018 Dodge Charger Sedan (A46684)
2018 Dodge Charger...
