Re: Pulling Cat5e wire thru 1 1/4\" poly pipe
RE:
<font color="green"> although I understand the "replace it every 5 years" argument,
</font>
My point wasn't that I expect it to fail every five years.
My point was that if you do a proper job of putting in the water-tight conduit, you won't need the direct-burial-rated cable.
Conversely, if you are going to use the direct-burial cable, why bother with the water-tight conduit?
Using both is needless overkill (IMHO).
Yes, the cost per-foot price difference for the direct-burial cable is going to be small for such a small run.
However, the hassle factor may not be. If you are not in the trade, purchasing a small quantity of the special grade cat 5e may be more hassle than it is worth. They are unlikely to have it at the local box store. You will get stuck buying a full 1000' roll from a trade supplier. They will only be open until 4 PM. Without a pre-established account, you will get the cruddy walk-up list-price.
Ordering it on the internet might be easier, but then it costs shipping and takes a week to arrive.
I do like the cheap poly "conduit" idea. Assuming you can install it without putting a hole in it and you seal the ends, it gives you reasonable protection for regular indoor rated cable. And it gives you the ability to replace a line IF necessary or add lines if desired.
Some people like a bit of overkill, and others like a bit of insurance against a poor installation. If that is the case, go ahead and put the direct-burial cable in a water-tight conduit.
- Rick
Footnote concerning 100-base-T ethernet wiring:
Even though the common cat 5e wire typically has 4 pairs, only two pairs are used for ethernet signals (up to 100-T). If a pair fails, you can substitute one of the other pairs if its undamaged. If you suspect (or know from a tester) that only one pair has gone bad, this trick may be worth trying before pulling a new line.
Of course this trick doesn't help at all if the problem is that your 3-year-old has cut the cable clean through in the basement with her play scissors "just like daddy does".
RE:
</font>
- Rick
