Pulling out a stuck car
   / Pulling out a stuck car #1
Tul01
Manitoba, Canada
2015 John Deere 5115M, 1928 and 1945 hand start John Deere D's,
Today had a learning experience. We have had heavy winds with lots of drifting snow for the past 24hrs. A chev malibu got stuck in the middle of the road near my FIL's place down the road from us. They dug for approx 45mins with no luck (-34) After he couldn't find a suitable attachment point for his snatch strap he attached it to some sheet metal under the "bumper" and not surprisingly on the second jerk, pulled the tin and bumper off. I went and reluctantly got out the tractor, thinking even with FWA it would spin. Found traction not a problem, but started questioning the attachment point same area same problem. I had talked to a tow truck operator in the past and asked what they were doing on these cars with no tow points. He said they are putting a strap thru one of the rear wheels and skidding it back onto the road. I decided we had nothing to lose. Used a short piece of chain thru the wheel and it skidded like a champ with gentle pressure from the tractor. My long winded leadup is does anyone have any experience with towing these cars out? Is there a better way or is this tow truck shortcut the best way. I am reluctant to pull on the wheel but maybe that is the only way.
Thanks, Brent
   / Pulling out a stuck car #2
Can't help ya other than relatey experience from about 15 years ago.
My wifes car slid off the drive into a snowbank. I couldn't drive if out so I got the tractor out. I couldn't find a good attachment point for the chain. I found a hole manufactured in the unibody frame rail that would accept the hook.
This was a 1997 or thereabouts, Chevy Cavalear. When I pulled on it with the tractor, the chain hook worked like a can openner. Not good at all.
   / Pulling out a stuck car #3
Tow truck driver told me the same thing. Said the wheel was the strongest point on a car. And you are right, there are few or no tow points on most cars. Why do I drive a truck??
   / Pulling out a stuck car #4
I hear ya -- my wife made a mistake of driving my chevy malibu over the yard as a shortcut to get around full driveway on soft ground and got stuck. I couldnt find a suitable place either. I ended up slipping a small chain hook in small slot on one of frame on one side near axel. Mind you - this was crawling on wet soggy mud/grass trying to slip the chain in where it sunk all the way to frame.
Someday -- which is probably never, I will get the proper t slot hooks that tow truck drivers use.
   / Pulling out a stuck car #5
"J" hooks or "t" adapter for the oval slot in frame like the tow trucks use. Seems like you would bend the wheel and among other complications pulling on the wheel.
I think the other thing that is important is the slow steady pressure of the winch. That is how I tried to pull the car today. Felt much less violent than the snatch strap I usually use with my truck. That being said yearly I probably average pulling 10-20 vehicles out of the snowbanks and ditch with my truck and have usually had good luck I guess. I keep an anchor point inthe hitch all winter for convenience. I just don't like starting the tractor up for a short period of time in this cold. Thanks for the replies.
Brent
   / Pulling out a stuck car #7
This suits me well, we run a 24hr towing service and get many calls in the winter for this very thing. The main thing you have to look at is resistance and go from there, thats what you're battling. Wheels are generally fine for getting a car back up onto the road. Snow generally doesnt add a lot of resistance it just decreases traction. I see people with big souped up 4x4 trying to pull merely stuck cars out with little sucess because of traction issues. Meanwhile i'll drive my ice grousers into the pavement and pull it out without a hiccup. Lately we've been running into higher resistance pulls though from a lot of warm to cold days. The snow gets really, really dense and the snow plows also dont help. If a car goes into the ditch we have a hard time even digging to a good hook point its so thick. This I would consider a harder pull, if you dont have traction you wont pull them out, you need to be anchored pretty well.
The wheel definatly arent the strongest part of the car but for where they are they are usually acceptable. The best way to pull on them is low and somewhat perpendicular to the face of the wheel. Cars stuck in snow have to be pulled in the direction you want them to go, they dont generally track where you want them to go with their own wheels, to a point.
-In deep or really dense snow you want to pull them forwards if at all possible, if you pull the rearwards you run the risk of pulling bumper covers off and the like, the rear bumper covers are generally higher than the fronts and the car plows most of the snow down before it would get to the rear as well.
The best place you can pull from is the front cradle. This supports the engine and trans and is very structural. Keep in mind wires and lines are run around them typically. Another decent point is lower control arms, again this is totally by situation. Some are very thin and small and ****** but some are quite beefy and pulling on the right place (close to the cradle) is ok.
* Have to keep in mind a lot of the newer "chrome" wheels are just aluminum wheels with a plastic chromed cap glued to it. They do crack!
Wheels are favored for their easy access but sometimes things just dont work that way. Sometimes you have to dig.
Big j-hooks arent great for recovery, they become cumbersome in tight spots, are likely to hook onto other things you dont want them to and are more apt to slip off thing. I dont do any recovery with j-hooks.
That was the perfect answer from someone that knows what they're talking about. Thanks for the indepth experience. Exactly why I posted it here on TBN. Best site, wide experience.
Thanks again
Brent
   / Pulling out a stuck car #9
Guess I am used to European cars where a tow hook is required. My cars have a hook in a container in the trunk lid that screws into an attaching hole. Requirement is it be strong e ought to support the full weight of the car. I thought I saw those on Japanese cars too but maybe not on American made Japanese cars - cost savings. At least my Ford pickup has as dive hooks but they have only been used to tow people out, not to be towed - yet.
   / Pulling out a stuck car #10
Last thing I towed was a Toyota Rav4 that was sitting in a brook with ice water up to the hubs. I couldn't see under the rear end without putting my head under water so was going by feel. Didn't find anything resembling a tow hook so went over the rear wheel mount being as careful as I could of the brake line. Got it out no problem and no damage. On dry land in the daylight it has a nice tow hook about eight inches from where I was looking for it. Some of the hook points you find were for tying down the car in the ship they brought it over in and they leave them out of the ones assembled here.
   / Pulling out a stuck car #11
My car has a small cover in the front (maybe the rear) bumper. Apparently, you take the cover off and thread in the eye hook that was included with the car and pull from there. Never had to do it, hope I never do. Every car has a attachment point, they all traveled by car hauler and were all strapped down somehow. Can't see them using the wheels for that.
   / Pulling out a stuck car #12
I had to help recover a Honda Accord that had high centered itself on a snow drift this weekend on my private road. Couldn't find any tow points on the front, the only thing I found was a tow point on the back end.
I couldn't get the tractor around the car so we dug out as much snow as possible from the underside, routed the strap from the front to the back and ever so gently I pulled it forward with the tractor. It only took a nudge but I wasn't sure if the attachment point was meant to be pulled in that direction but it did the job.
I have a new appreciation for German cars, strong tow points front and rear, no digging required.
Jason
   / Pulling out a stuck car #13
Maybe a lesson to take from this is to look at your vehicle now and record the best front and rear tow spot. Write it down and stick it in the glove box.
   / Pulling out a stuck car #14
Jason
What I was thinking.
   / Pulling out a stuck car #15
Haha, a lot of the newer cars they are running tire straps over the tires and ratcheting them down on the car hauler. Some still have reinforced holes in the frame, most of which you have to stick a finger in to figure out if they are (very bad idea safety wise.) they also need to be pulled evenly on a lot of them to prevent damaging the frame if there is very much resistance.
   / Pulling out a stuck car #16
I got one that is funny. Back about 1990, I had a 89 Geo Metro. I was driving very slow, because the road was very icy. I lost traction, and very slowly slid nose down into a ditch. A tow truck was called, showed up, put the hook on, started the winch. The tow truck slid into the ditch!!! So now the tow truck called another tow company. This guy showed up and refused to tow the tow truck unless he got the tow - !!! The 1st guy was madder than ****, called the guy every name in the book. The 2nd guy was laughing his azz off!!! But he towed me out 1st, then towed out the 1st guy. I was laughing the whole time!!!
   / Pulling out a stuck car #17
These are not used for recovery! If you're talking about the one that scews into (generally the bumper area) its not for pulling your car out of the ditch, dont use it! It may be strong enough to support the car if you're pulling directly straight on, but thats it, any directional pull other than straight on can and will rip that right out.
I have used these on porsche/ bmw and the like and still even cringe pulling the car up onto the flatbed (what its intended for).
   / Pulling out a stuck car #18
Do to libilty and the crazy nature sue happy folks... I make them wait until the snow/ice melts. I won't open the garage doors or start a tractor when someone gets stuck unless its family... and most of my family has their own tractors.
mark
   / Pulling out a stuck car #19
mark
Just for this reason, I won't pull anyone out either. The most I've done is spread the ashes from my coal furnace on the highway, so they can get traction.
   / Pulling out a stuck car #20
When you pull using the wheel, does the wheel just slide? I assume the wheel is locked up so it doesn't turn?
1999 John Deere 7810 (A60462)
1999 John Deere...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
2007 Yamaha Rhino 660 (A56438)
2007 Yamaha Rhino...
John Deere 4600 (A53317)
John Deere 4600...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
