Pump suggestions?
   / Pump suggestions? #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
I'm going to have the timber thinned and I plan to pile the slash, or at least have it bunched up somewhat so I can build some little piles with my tractor. The state forestry people have to deal with rules written for industrial scale operations, which I am not. When I logged 15 years ago they wanted a water source and a pump to spray with. The pump I bought couldn't generate pressure, it was only good for jobs like filling a tank but the state guy didn't notice that. Putting a nozzle on the hose would damage the pump.
Well, I sold the pump and now I need another and I'd like one I could use with a nozzle. I have seen PTO driven pumps, but I don't know if they would fit my needs.
So what kind of pump can I use? Are there some PTO driven pumps that would work? I presume it would have some sort of pressure relief or a bypass of some sort. A PTO driven pump would be best because the tractor is so convenient.
   / Pump suggestions? #2
Typically a centrifugal pump is used for spraying water and you will want something that makes at least 60psi at the nozzle- some pressure loss with height and distance.
Most don’t bypass- they just make heat...which is bad! So you either move a little water through it or turn it on when you need it. A built in pressure relief adds a lot of cost.
Advance SC750 28in Floor Scrubber (A55787)
Advance SC750 28in...
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
2017 ISUZU NPR 16FT BOX TRUCK (A54607)
2017 ISUZU NPR...
CRAFCO INC. MAGNUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGNUM...
2025 LandHonor LHR-LB9510 Leaf Blower (A52378)
2025 LandHonor...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
