Put the finishing touches on the barn this weekend....
   / Put the finishing touches on the barn this weekend.... #11
Lee, it look like your big doors rest flush with the slab...there is no step to keep water from seeping under the door, I know it will seep since my door is that way...if I only knew then I would not have water seping through the seal every time it rains.
The shop does look good though.
I know what you mean by fill, I am still adding fill to the lean to side of mine to level it out some.
With the amt. of fill you added it my settle some after a few years...hopefully it won't be under your slab.
we worked the dirt as best we could and put the dirt down in very small lifts then spread with a dozer and ran back over it with the next lift with a cat 420 4wd ext hoe backhoe. It was working very well. I'm sure it'll settle some but hopefully it'll be ok.
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
Electric Mobility Scooter (A51694)
Electric Mobility...
