Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 6,011
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Look I'm not sure if you are purposely doing this as egging people on or what. A ranger DOES NOT and HAS NOT been constructed using 3/4 ton truck components. There is not a 3/4 ton compact truck class. Doesn't exist in north america.
The 4x4's or 2x4's do not use 3/4 ton truck components, the use compact truck components.
The 4x4 ranger used Ford 7.5 or 8.8 semi-float rear axles. A 3/4 ton of that vintage uses a 10.25" full floater Sterling axle.
A ranger uses a lightweight transmission produced by Mazda. A 3/4 ton used the huge ZF-5 manual transmission.
The smallest engine available in the 3/4 ton was a 302 V-8. At the time, there were no V-8's in the 1/4 ton chassis. Later, the explorer which partly shared the chassis became available with a V-8. The ranger never did get a v-8.
The ranger is not a 3/4 ton truck. The 3/4 ton or 250/2500 class is all full size trucks and nowadays has nothing to do with the payload capacity of the truck.
The same is true of 1/2 tons. You can't call it a 1 ton just because it has a 1 ton payload capacity.
Although they've all probably rusted out and are all gone now, in the late 70's or early 80's Toyota had a compact pickup that clearly said "One Ton" on the side of it. It only had a 4 cyl engine and I doubt it could tow much, but it apparently had one heck of a set of springs under it. However, GM and Ford never made any similar beast.
