pvc pipe along exterior wall for termite treatment
   / pvc pipe along exterior wall for termite treatment #11
</font><font color="blue" class="small">( You dont want that stuff to get into your drinking water or someone elses )</font>
Maybe times have changed, but when I used to build for a living, the foundation area was flooded by tank truck with termiiticide before the slab was poured.
   / pvc pipe along exterior wall for termite treatment #12
Forgeddaboutit. Resistance is futile. The Formosan termites will make it to Fla. in no time if they're not already there. Formosan termites don't rely on soil or moisture. They simply jump on your house and start eating. Unless your house is solid metal or concrete, it will be eaten flush with the foundation in no time. Munch munch munch, next!
All seriousness aside, if you have no roots or buried sticks close to your slab, I wouldn't over-do it on prevention. I wouldn't want to make it too easy to dispense poison. Follow directions carefully, and make sure the termiticide is buried the proper depth and in correct quantities. If it filters to the surface, it can have a devistating effect on local wildlife. I have seen frogs, toads, and green lizards so spastic they could not feed themselves, and slowly waste away. It's a pitiful sight seeing the little critters trembling and their bones showing. I suspect the termiticide was over-applied (or buried too shallow) and it soaked to the surface. Ground water contamination is also a concern. Don't know about the latest termiticide. It may be more critter-friendly and groundwater-friendly.
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2000 HONDA FOURTRAX 300 ATV (A51247)
2000 HONDA...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
