PVC Water Line Pulled Loose At T-Joint/Shrubs Might Go Away !!!
   / PVC Water Line Pulled Loose At T-Joint/Shrubs Might Go Away !!! #11
Oatly sells a two piece set with the Purple Primer and Medium Duty Clear Cement that is good for sprinklers. Always buy new when doing a project. The Cement will thicken over time and not work properly if it's old. The Purple Primer will separate over time and become clear looking when it's no longer any good. It's not worth the risk of failure to use old cans of either. For me, it's it's been a few months, that's too old, and I buy brand new.
Don't think I've ever had issues with the primer separating, but yeah the glue doesn't stand up well to storage. I'll just by the smallest can and consider any leftover to be disposable.
   / PVC Water Line Pulled Loose At T-Joint/Shrubs Might Go Away !!! #12
The primer lasts longer then the glue. When it's bad, it also loses it's strong smell. Since the cement gets used up a lot faster then the primer, I sometimes have several bottles of primer in my truck. It also spills easier, and it's not uncommon to lose half a can of primer when doing a project!!!!
The vast majority of my PVC work is drain lines for bathroom remodels.
   / PVC Water Line Pulled Loose At T-Joint/Shrubs Might Go Away !!! #13
It varies here a lot from no plastic pipe above ground to anything goes.
One of my each friends had nothing but trouble before he went to s slip PVC water line
Soil can be expansive and earthquake faults run through the area.
75 years is not bad for buried 1" galvanized...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
greenworks (A53421)
greenworks (A53421)
