QH 3 point draw stabilizer.
   / QH 3 point draw stabilizer. #1
massey collector
Bronze Member
Michigan
1938 Massey Harris 101 Or which one
Going to attempt to build a 3 point draw bar stablizer from the far out side holes in the draw bar up to the center hook.
Will be able to add a couple trailer balls and just back under the coupler.
:D Al
   / QH 3 point draw stabilizer. #3
Should not be too difficult.... Might even be easier to purchase, IF you are in Australia...
3 Point Drawbar Towbar Stabilizer Tractor Kit
Or copy this one....
https://www.tractorbynet.com/forums...ar-bx2200-430474-cross-drawbar-stabilizer-3-a
Dale
Based on the thread title - I think he's looking to drop the drawbar into a Quick Hitch (QH) so both of those would have to be modified slightly to use the Top Link Hook on the QH but both of them are pretty cool ideas and could be adapted fairly easily.
I'm also going to be the first "Safety Sally" and put a general reminder for whomever may come along - Remember that the 3pt has no downward force so if the load on your trailer gets heavier behind the axle(s) then the tongue will lift and take the 3pt right along with it.
If you're looking to pull loaded trailers with a 3pt drawbar, you need something from the draw bar to the top link receiver on the tractor to keep the 3pt from raising.
Also - the OP stated he was intending to use a ball hitch so locking the drawbar from rotating is good (actually pretty much required), however if someone were planning to use this with a drop pin / agricultural type hitch, locking the drawbar is BAD. The drop pin style does not have the range of movement a ball hitch does and the rotating of the drawbar allows for the up/down articulation of the connection over uneven terrain.
You guys probably know this already, I just wanted to add it for the benefit of others who come along and might not. ;)
PALLET OF PIPE CLAMPS (A50854)
PALLET OF PIPE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
