RonMar
Elite Member
ymurf said:You guys are a great help.I hope i am not asking to many questions but i have another. I am going to get my fluids tomorrow and am having a heck of a time now,Thought i had it figured out but now i need you guys advice.On this link it says to put the same hydraulic fluid in the tranny and the lift.Service Bulletin from Tractor Outlet Jinma Tractors Loaders Backhoes
But i see allot of posts on here to run different oils in the tranny and lift?I need some help here before i buy the wrong stuff.
Gear oil in the transmission and differential/axle cases(yelow metal friendly, low foam). Since you didn't fill out your profile telling us where you are at, I can only make a guess as to weight. 80W90 is typical, but you may want something heavier for a warmer climate.
Probably AW32 Hydraulic oil in the hydraulc resovoir/3PH lift box, but again this can be determined by your local climate. If you go to your local Napa, they will probably have 5 gallon pails of what is used in the area for hydraulic oil.
