3Ts
Elite Member
Thanks for rattling my brain, I knew that >>>>>> getting the proper drop. However, I wouldn't have known that 1/4 : 1' is required for a sewer system.
If'n my figgerin is correct, 60 feet of solid line from the house and shop to the common tank would put the entry to the tank @ 15". That should be no problem, and a man may want that tank even deeper.
With these systems, is there a maximum depth to set the tank?
The aerobic systems I see around here have exposed mushroom looking tops above ground. ??? I suspect the solid line inlet is situated somewhere between 3/4 to the top of the tank. ???
I need to start looking around here and find a house being built and ask when the septic install is, then I could see the "guts" of the system.
May want to verify the slope requirements. My understanding is that the 1/4" per foot is for 3" and smaller pipe with the 4" pipe being 1/8" per foot.
There are a number of requirements imposed by the "Texas Commission on Environmental Quality"
On-Site Sewage Facilities (Septic Systems) - TCEQ - www.tceq.texas.gov
so you may want to spend some time going thru their information, there's also info from other sites that are easier to read than the governments.
I've not found anything that limits length of sewer line other than the drop. I have at least 200' of sewer line from my RV pad, past my cabin, past my barn, past another RV pad, and finally to the septic tank. And I have another 150' of sewer line from my house that ties into the mid point of that 1st line and no problems with any of it. Each section of pipe was carefully measured and adjusted for slope before burying any of it and there's been no problems.
There's also plumbing codes that deal with the piping to the septic tank that are well worth paying attention to (including the type of fittings) and those can be found in a number of books. The best ones I've found to be published by Taunton Press and articles from "Fine Homebuilding" and the "Journal of Light Construction". All of which will require a few $ to peruse but are well worth the money. I can get you the ISBN number of what I consider to be the best ones if anyone is interested. And no, I don't get any kind of compensation for this recommendation other than knowing I've helped someone avoid some mistakes.
