Question about electrical connector on DK 40SE
   / Question about electrical connector on DK 40SE #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
I am a new owner of a DK 40SE. There is an unused/unconnected electrical connector at the left rear of the tractor. Can someone tell me what this connector is used for?
   / Question about electrical connector on DK 40SE #2
No one has answered you yet. I don't actually know what it is but my dealer told me it was for trailer lights. Not sure if that is correct.
   / Question about electrical connector on DK 40SE #3
It is probably the 'owner use circuit'. Check your fusebox for an extra fuse marked 'customer use'. Run a test light to ground and see if it is a live circuit when the tractor is running; it may be controlled by a switch near the 'console' - check owner's manual for location of switch. Pull associated fuse to verify the particular circuit/fuse, and see if test light goes dead.
   / Question about electrical connector on DK 40SE #4
I thought that it might be for cab lighting if you were to opt for a hard cab....Mike.
   / Question about electrical connector on DK 40SE #5
There is also one of those connectors on the CK models and there is no cab options for CKs. Email Wallace Equipment, he will know.:rolleyes:
Thanks for the replies. I'll have to look at it a little closer and check it out with a test light.
   / Question about electrical connector on DK 40SE #7
mine has a round plug with more than two wires, Its for trailer lights "left right rurn signals, electric brakes, run lights.
   / Question about electrical connector on DK 40SE #8
Deon, Have you found out what that connector is for? I also have the same Kioti.
THANKS,
elstonb NH.
   / Question about electrical connector on DK 40SE #9
If it is on the rear of the tractor usually on the passanger side it is for a optional rear work light.
1979 Miller 28' Tomato Trailer (A44502)
1979 Miller 28'...
2021 ARISING INDUSTRIES, INC 24 T/A ENCLOSED TRAILER (A47001)
2021 ARISING...
Gravely Pro-Turn 460 (A47307)
Gravely Pro-Turn...
Mayrath 6x21 Truck Auger (A46502)
Mayrath 6x21 Truck...
2006 Lincoln Mark LT 4x4 Crew Cab Pickup Truck (A46684)
2006 Lincoln Mark...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A45336)
2018 Skyjack...
