question about hydraulic rear bladeswith 3 rear remotes
   / question about hydraulic rear bladeswith 3 rear remotes #1
BGigHarbor
GIg Harbor ish
.l5460, bcs 725, 852
Say a person had a tractor with topntilt and 3 rear remotes.
Say they were considering buying a LP RBT3584 which is a rear angle blade that can have manual or hydraulic angle, tilt, or offset.
Seems likely the hydraulic angle is a no brainer.
How best to put the other two remotes to work? Offset seems it would be handy but it would take away top or tilt.
And is tilt done best on the blade or through the 3pt tilt?
Crimenies, is this a case for 4 rear remotes?
All hypothetical of course.
   / question about hydraulic rear bladeswith 3 rear remotes #2
Yes 4 remotes, "T&T", offset and angle on the blade. Just get the ratchet for tilting the blade. You want the tilt on the hitch so that you have that capacity for your other implements. Very very seldom do you need to tilt more that what the hitch will do, and if you do, then you manually tilt with the ratchet on the rear blade and fine tune that tilt with the 3pt hitch tilt.
I just finished a remote setup for a guy that has an M7040. He needed 6 total rear remotes for his tractor. Not only did he get my "T&T" set, but with his Land Pride blade he got all 3 functions hydraulically operated along with hydraulic operated gauge wheels. So he used 2 OEM valves for the "T&T" and the 3rd unit goes through a 3 diverter valve bank to end up with the 4 sets of outlets that he needs to operate his rear blade. :cool:
   / question about hydraulic rear bladeswith 3 rear remotes #3
Brian, can you tell us a little about that 3 diverter valve bank?
-Jim
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
Pallet of (8) 8 Lug Misc Wheels (A51573)
Pallet of (8) 8...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
