Tires Question about liquid in rears
   / Question about liquid in rears #1
Tibbits
L3430 GST, BX1500
I got a used Kubota L3130 with R4s a couple of weeks ago. I just got around to checking tire pressure. I knew the rears were liquid filled, but I get liquid when I press the valves at their highest point. I've tapped the rires and it seems the liquid stops several inches from the top (as it should). Could it be the air pressure is so low that liquid comes out when the valves are pressed at top dead center?
   / Question about liquid in rears #2
Maybe you miss judged the level ?
I believe the level is supposed to be higher then steel wheel.
   / Question about liquid in rears #3
The liquid should be just over the top of the rim...
That should explain it..
Want the rim to be always under the fluid...
J
   / Question about liquid in rears #4
I have the same issue.. Even with the valve at 12 o'clock I still get liquid..
But you can buy (which you should use) a liquid pressure gauge - I got mine on ebay, but TSC does carry them..
b
   / Question about liquid in rears #5
Bet if you jacked tire off ground,than put valve at 12,and let all air pressure out,you wouldn't get any liquid?
   / Question about liquid in rears #7
Well,maybe you would win,if liquid was above valve stem:D
That explains it. Hopefully my TSC has a liquid gauge in stock. And hopefully my little air compressor won't get a backflow drink. Thanks!
   / Question about liquid in rears #9
For anyone that has a question whether a tire has liquid or how much, just expose the tire broadside to the sun around mid morning and in just a few minutes the tire temperature differential will tell without a doubt where the liquid line is. This temp. difference can be felt with your hand and as the day and ambient temperature progress upward the liquid elevation will rise just a bit.
   / Question about liquid in rears #10
That is very true.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52707)
KNOW BEFORE YOU...
UNUSED FUTURE FT-RT57-57" HYD TILLER (A57193)
UNUSED FUTURE...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
Year: 2015 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2015 Make...
