Question about serial numbers
   / Question about serial numbers #13
Welcome to TBN :)
I moved your thread to the Ford/New Holland Owning & Operating Forum.
   / Question about serial numbers #14
To see mine clearly i sand blasted the area, and the 2 places on the motor then spray painted.
You couldn't hardly see them to start with, now even after painting you can read them clearly.
I used a paint remover and was able to get clear down to the metal. Still only two lines. However with help I think we have figured out that my tractor is a 1967 3cyl diesel, made in England.
   / Question about serial numbers #16
You can match up numbers from other parts of the tractor to confirm that. Anything under the hood?
Are there any stamped in numbers on the left side? Seems i read replacement transmissions were sometimes marked there.
DS
Yes we (another forum member checked the transmission numbers and freeze plugs--with all that information it was concluded what I had. I have ordered a wiring harness from the local dealer. It should be in next week. Actually the wiring harness comes in two parts (packed, shipped, priced and sold separately) I was trying to put the old wires back on and determined that much of the old insulation had cracked off the wire so I felt it would be better to start over with new wire.
   / Question about serial numbers #18
You could have gotten a after market Diesel harness for less.
Some of the wire ends are not right, but easy to change. I like to pack a bit of Vaseline in the connectors for extended life.
   / Question about serial numbers #19
glad to help
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
2018 Doosan C185 Trailer Mounted Air Compressor, Model 484289UBACG07, S/N C185WD20T4F, Deutz Diesel (A59076)
2018 Doosan C185...
LONG 2460 TRACTOR (A58374)
LONG 2460 TRACTOR...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
