Question Carb Linkage GOVERNOR SPRING
   / Question Carb Linkage GOVERNOR SPRING #1
Amos1
West-Central Illinois
Ford 861 Powermaster
Hello....
I noticed the spring was broken that fits on my carb linkage (861 Ford) and I bought a new one.
But I can't figure out where one end attaches?
The "Long End" connects to a hole in a plate on the linkage (right under the Air Cleaner), but where does the other end connect? Anybody know? It goes somewhere under and close to the battery tray I think.
Thanks- Dennis
   / Question Carb Linkage GOVERNOR SPRING #2
seems like i posted a reply to this somewhere.. did you double or cross post this?
there is about a ?? 8" spring from under the bat box, passingthe bellcrank to a rocker.. etc. is this the spring you are looking at? 8" may be wrong.. I'm going from memory.. tractors are at the farm and I'm at work... whodat or rickb can verify..
Yes, I posted on the Ford board first, but didn't seem like many were looking at it, so I reposted on the main "repair" board...
Sorry for any inconvience that may have caused....:eek:
Yes - the spring is about 8 inches long...
I will connect it to the tab under the battery box!
Thanks...
   / Question Carb Linkage GOVERNOR SPRING #4
here's a diagram of the linkages too, in case you dind't get them. don't show much.. but if you pulle dit apart it will help you get it all back together..
Yep, that's the diagram I ordered spring from - it's # 20...
Thanks, Sound Guy, for your help... Much obliged!
   / Question Carb Linkage GOVERNOR SPRING #6
glad to help, if it did.
good luck
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
PALLET OF WOOD AMMO BOXES (A58376)
PALLET OF WOOD...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
Caterpillar Loader Quick Coupler (A56436)
Caterpillar Loader...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
1000 Gallon Fuel Tank (A57149)
1000 Gallon Fuel...
