turbo36
Veteran Member
- Joined
- Apr 20, 2004
- Messages
- 1,391
- Location
- Michigan
- Tractor
- JD X739 AWS (3), 2016 Toolcat, JD 2038R
I have a "condition" with my power steering that I was told is normal to all 2520's; when I turn the wheel the steering "freezes" or "pulses" back against my efforts. It is worse when cold, and does not seem to be rpm dependent. It was so bad at first that if I turned the wheel fast enough it would literally "lock up" and would not continue in the same direction until I released it. My dealer worked very hard to get it smoother but it is still there. The explanation from Deere Engineering was this is normal and due to the sharing of the steering pump.Has anyone experienced this?
The reason I ask now is that I drove a 2720 and the steering was butter smooth with no hesitation or jerking so I thought perhaps Deere upgraded the pump on the 2720 but the specs show it to be the same as the 2520.
The steering was so smooth I could turn the wheel with one finger instead of the two hands my 2520 takes.
