So what you are saying is that with/without conduit, UF cable is required??? So even single stranded wire would be a no-no unless it is UF (never checked but I doubt what I have on my spools is UF)? I guess it comes down to the insulation on the wire (I've played with that 3 wire underground wire before and didn't like it much...totally encased in molded plastic with the insulated wires inside...a lot of band aids from the knife cuts). So what is different in the wire that the utility uses? That insulation peels off pretty easy.
THWN (Thermoplastic Heat and Water-resistant Nylon-coated) and THHN (Thermoplastic High Heat-resistant Nylon-coated) wires are the type of loose wires that are ok to use in conduit.So what you are saying is that with/without conduit, UF cable is required??? So even single stranded wire would be a no-no unless it is UF (never checked but I doubt what I have on my spools is UF)?
no, what im saying is if you use conduit, the only style of romex like wire you can use is UF rated. Regular NMB style romex ( that used in wiring houses) is not allowen in conduit. You can use any individual wire rated for conduit use, suxh as XHHW, THHN, Etc..
Only standard ROMEX is not allowed.
Romex is a NM listed cable. There is nothing in the code that disallows running it in conduit. If underground, moisture resistant is required, but that does not exclude all romex. NMC is rated for outdoor use and can be used in conduit outdoors.
paul
