Question for Snow People
   / Question for Snow People
I am going to agree with this. We get a lot of these little 3 or 4 inch snows here and I just put the blade on the back and angle it 15 degrees and go. Adjust your top link as needed and take off at a moderate speed, You don't have to look back all the time, just watch your front tire and keep it on a line you want to cut. Back blades work well for small to medium snows. if you are on gravel, you can adjust it to not dig in so much by adjusting the top link, and you can hear how you are doing, if neccessay adjust your lift up a bit. You will get better the more you do this.:)
I tried this method and for 3-4" works well. If ever (repeat ever) we'll get 12" or more, I'll consider the other methods. I have been waiting for this snow since 2010 just to try my blade. Now I'm happy. I'm ready for the next occasion which will probably not happen this year.
   / Question for Snow People #22
Coming from the snow capital of the USA, View attachment 360661
I like most others have said would just drive over it but knowing how South deals with even a 1/2" I would mount a piece of 2"x6" or 8" to the back blade so you are actually using it to push the snow and not the blade. You can also push with the back side of the blade if you don't want to add the 2"x. for the amount of snow you are talking about this will work fine.
Tug Hill plateau was on the news the other nite......276ins.and still counting.Snowing like crazy right now.
   / Question for Snow People #23
for NC I'd look at those plywood ones guys attach to the axle of a car or truck,, 3 inches is no load if you have it angled, look on youtube for some ideas,, I've plowed tons of snow over 40 yrs of driving, save your money , and rig up an atv blade with one cut in two to make it wider than the 5 ft they usually are.. or even a 2x8 or 2x10 can be used as a push surface
   / Question for Snow People #24
2 or 3 inches try the blade in reverse. It snowed 6 inches in western NY today we just broke 100 inches for the year. It still is blowing around the driveway, I'll plow it tomorrow :).
   / Question for Snow People #25
If you have a steep driveway like mine, 2 or 3 inches will stop a 2wd vehicle from going up. I too didn't used to worry about it, till I got my first toy, a old Gravely L with a blade on it. We got a 3 to 4 incher, and I decided to get out and push it off to try it out. I could not believe it, that night while I was at work, a guy that had a scanner at work said he thought he had heard there was a structure fire call to my house. Sure enough, that night my wife was using the clothes dryer and it had caught on fire. I rush home and there are fire trucks everywhere, several waiting down at the bottom of the hill because there is little room at the top at the house. Everything was ok with no damage except to the dryer, but it was a wake up call for me. There was no way those fire trucks that were up at the house would have made it without me "playing around" with my "new" Gravely. I also worry about some of my neighbors, and help some of them get cleared out for the same reason, in case a rescue squad or something needs to get up their driveway in a emergency.
I have a 7.5 foot blade on my f250 now, and even though I have feet on the blade, it still digs up gravel. What I do is when I push my gravel drive, I put one side of the blade in the ditch, and use it at a slight angle. It digs in some, but the gravel that it moves ends up in the right lane instead of the grass. Later on all I have to do is take the Gravely and spread the gravel back out to get rid of the "winrow" of gravel on the right side of the drive. I have a parking lot I am responsible for also, so I do need a blade that will clean up pavement pretty good at the same time.
   / Question for Snow People #26
I guess you will be cleaning the lint trap on the dryer more often, now. Also make sure the vent to the outside is clear and clean. You were lucky.
   / Question for Snow People #27
Lucky indeed.
Perhaps it was past time to change those thermostat things in there. There are usually two and pretty cheap. I think one is supposed to be a breaker like, that cuts in and out as things get too hot. If that fails, there should be one that works like a fuse that once it gets too hot, your done till replaced. Perhaps they werent working?? But once lint plugs up enough inside the dryer itself (or even the outlet pipe), they are supposed to fail before things get hot enough to start a fire.
Not sure if the dryer is salvageable, or if you even want to. But unless the fire dept or insurance want to look into it, I would be tearing it apart to see what failed just for my own piece of mind.
   / Question for Snow People #28
The dryer thing happened a long time ago, I was just telling that story to emphasize the importance of keeping your driveway clear, even though you may be able to get out like it is.
The dryer thing turned out to be the plastic hose that was leading out to the outside vent. Guess what? You can't buy the plastic hose anymore, safety problems with it! So everyone may want to take a gander at their dryer hose, if it's that white plastic stuff, get rid of it and put the metal foil hose in it's place.
   / Question for Snow People #29
no offense but i would have to disagree with the snow capital of the USA comment... :laughing:
   / Question for Snow People #30
Fire trucks have NO problems navigating a few feet of snow...
Rigid heating/cooling vent pipe is much better. Even if a fire does start inside the pipe it won't go anywhere. Not as easy to work with but with the seems tapped with foil there is little if any risk of fire.
Sent from my iPhone 5s 64Gb using TractorByNet
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2016 Kobelco SK75SR-7 Excavator (A50490)
2016 Kobelco...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2016 CAT 289D Track Loader (A50490)
2016 CAT 289D...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A50505)
2018 INTERNATIONAL...
