Question on faux welding
   / Question on faux welding #21
As for the comments of getting revenge- drain oil, weld sign on door, dirt.... come on guys ! :rolleyes::D (family forum remember ?;)) I know it's in all name of fun,
Yes you are very correct. :D:D
Irritated sufficiently most of us would contact the proper authorities and have the vehicle legally towed.:D
   / Question on faux welding #22
Don't try to weld with a battery, if your welding rod happens to stick, good bye to the battery and your cables.
   / Question on faux welding #23
Letting the air out of a tire works well.
And air out of 2 tires even better but reserve the 2 tire method for the violaters that did not get the first message!
   / Question on faux welding #24
By far the easiest thing to do has already been suggested.
Just use bolts a little longer than needed, then booger up the threads behind the nut with a chisel & hammer, and/or bend the end of the bolt.
The nut will NOT come off.
And if you think those guys might then want to pull the post out of the ground, dig a hole and set the post in plenty of Sackrete. This will make it so clumsy and heavy that even if they would pull it up, they would be unlikely to carry it off. This way they would probably assume the county did this and wouldn't blame you personally and retaliate.
Doing anything to their vehicle's would just be asking for trouble.
Ronnie
   / Question on faux welding #25
Ronnie
Especially if you welded the signs to their hoods.........
   / Question on faux welding #26
To make bolts un-removeable I used to try removing them carefully with a ball peen hammer. :rolleyes: The bolt will mushroom to the point that cutting is the only alternative. :)
Have you tried talking to the worst offenders? One by one you may be able to come to an amicable arrangement.
A game cam to record the sign vandals may give you some insight as to who you should speak with first.
As far as signage goes, if there is no enforcement then the signs are worse than meaningless to these people.
   / Question on faux welding #27
You have to watch out for the occasional person that you can never reason with, and who will make it his life calling to make your life miserable, any way he can... too... They are out there.... Stay on the up and up... go thru the authorites....that is bad enough... TO THEM.....
   / Question on faux welding #28
Another simple solution- get a wildlife camera (motion sensing) secured to a tree aimed at the drive way. Either way, the thief and/or the people parking will be documented.
Another option, depending on the ordinance in place- may allow you to call a tow truck when the cars are there. Even better, apply to the town to be an authorized towing agent, tow them into your yard and collect the fees yourself......
Is there a possibility that the town can install some type of barrier or posts within a short distance that will prevent parking, but not impede you entry and exit?
Good luck!
   / Question on faux welding #29
I like the game cam idea.
Those signs are not cheap, and around here there's a pretty good reward for information leading to recovery of any signs. You may be able to make a little money on the side as a do-gooder thwarting the devious plans of villians.
Why not just play this straight.
Call the county the next time someone parks there, sign or no, it is a no parking zone.
Given the likely state of their finances, they will probably come out & put a ticket on the car(s). A few tickets and people will start to park in the right place. Even if they can go to court and fight the ticket because the sign has been stolen, this is a huge PITA compared to parking in the right spot.
And, the county will replace the signs. One that you recovered and put back up yourself has dubious validity.
There seems to be some disagreement with the county. The county actually dropped about 5 of these off for me to put up since they didn't really understand where the 'parking issues' were. This was done after a meeting with the Sheriff himself, TVA and TWRDA (or what ever Tennessee Wildlife Resources is called)
Signs came to me. The first one that I put up, quickly had someone parking right next to it. I called the Sheriff dept. The officer that came out looked at it and said he couldn't give them a ticket because the sign was facing the wrong way.
Don't know if I can type this easily...
As you come to this dead end, you have lake on left, our driveway on the right. It's a little culdesac for lack of better word. Since it was a no parking "area" I put the sign on the right BUT, the sign...how to say...was parallel to the road. Meaning it was "broadcast" to the entire (very small) area.
Someone parked just past the sign. The Officers logic was "the sign means you can't park "BEHIND" the sign so technically, they can't park in the woods. They can park BESIDE the sign. The sign has to be simply rotated 90 degrees before he can give them a ticket.
I was floored. This was after his boss and TVA agreed to make the entire road no parking (narrow road and parking on side can at times, prevent emergency vehicles from being able to pass if need be). Anyway... his statement was "I'll instruct my officers to ticket EVERYONE and let the courts decide"
Now this guy says he can't because the sign is not faced the right direction :confused:
My reality here is, it all comes down to which officer might respond. Some of them see the fact that if a firetruck (heaven forbid) needed to get through, might have a problem, therefore people shouldn't park on the shoulder of this narrow road. Other officers don't seem to really care. I never know which one might show up.
I also get 'flack' (disgruntled employee at county who's upset about Sheriff department who doesn't enforce some of the rules) from the County guy who puts signs up because "why should we keep putting them up when the sheriff department never does anything about them" (or some paraphrase of that)
Unfortunately, it's a bigger balancing act for me than I anticipated going into it.
Heck... One time, they put the no parking sign in a location where no on in my 25 years here has EVER parked. This is when they told me to move it to where the problem was (simply around the bend, off of the hill). As I was bolting the sign ONTO the post... ironically, a sherriff drove up. Sunglasses on, he said "I sure hope you are not stealing that sign"
The irony that they come by when I was putting the sign UP and have never lucked by when others are ripping them down! :D
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
POOL PUMP / FILTER MAYTAG WASHING MACHINE (A58376)
POOL PUMP / FILTER...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2020 Deere 325G (A57148)
2020 Deere 325G...
