Volfandt
Veteran Member
They were set to default. The manual was easy to follow and the programming procedure was easy.
I left the BPTS at default inorder to let the HP run at all outside temps and changed the AHLS down to 20 degrees, that way, if'n I ciphered it right, the gas furnace won't cut in unless the outside temp drops to 20 or below, or when the HP calls for defrost or when the thermostat is set to emergency heat.
Depending upon comfort, I could go lower but will have to wait for colder temps before I can determine the best balance between comfort & economy.
On a side note, this new Puron system seems to run more in AC mode but according to my records it uses less electricity. With this in mind I won't sweat the HP running more in heating mode as long as it can keep up with the demand.
I'm still curious about having the thermostat located above the main return. That is where the original one was and where the new dealer put the new one but, I did read a little blurb in the downloaded manual that indicated to locate the thermostat on an inside wall AWAY from any registers AND the RETURN(s).
Any thoughts on this?
VOlfandt
VOlfandt
