Question regarding calcium chloride in tires
   / Question regarding calcium chloride in tires
I had to buy new rims ....twice!
Both tractors were 25 years old.
If you are OK with that......no worries.
I'm more worried with catastrophic failure of the rims. I guess there will be plenty of warning before this happens?
   / Question regarding calcium chloride in tires #12
I've have tractors with cal. in the rears more than 30 years without any problems at all.
My loader tractor is over 20 years with the rears loaded with cal., they are just fine.
SR
   / Question regarding calcium chloride in tires #13
SR
They may LOOK fine, but when you need to replace tires, you will most likely need to replace rims also.
   / Question regarding calcium chloride in tires #14
I 2nd that idea
   / Question regarding calcium chloride in tires #15
If the tires are tubed (which the OP's are not) and leaks are immediately addressed there will be no rim damage. In 2017 I sold a 1976 Case 885 and 1970 Ford 4000 both with pristine original rims that had been calcium filled for many, many years if not since new.
   / Question regarding calcium chloride in tires #16
Not if you use the tractor much, you will wear the tires out long before the cal. affects the rims enough to need replacement.
At least that's what I'm seeing from myself, and my farmer friends...
SR
   / Question regarding calcium chloride in tires #17
Well many years ago all of our farm tractors had calcium filled tires.
This past year two of them had to have new rims the JD 4020 and one of the IH 656's.
The 560 got new ones a couple of years ago.
My 574 because it is not used for heavy work got about 10 hours of welding repair and grinding last year.
I think out of over a dozen tractors on the farm, one may still have calcium it the rest are all dry and carry wheel weights instead.
I have seen rims that rotted out in a dozen years and others that have made it 50 years.
I use iron and will not fill a tire with liquid if I can avoid it anymore,
that said calcium fill is the least expensive way to add considerable weight to a tractor.
   / Question regarding calcium chloride in tires #18
When calcium started as a weight for tires it was the go to method especially in colder climates. Calcium does too things, adds weight and prevent water fill from freezing. In my industrial refrigeration days calcium was used as secondary refrigerant for product freezing. We mixed it sometimes to withstand -60F degrees. At that concentration is is like syrup and very heavy. That was like 20#/gallon of water. 3 times the weight of the water. Non of the other common ballast liquids come even close to that. Proper ballast calcium has an additive to prevent oxidation of the steel rims. If you have constant leaks and add air often the additive will dilute rapidly and then corrosion sets in. In general it destroys the rubber much faster than the steel. The refrigeration applications were open to atmosphere so we had to add inhibitor often and add calcium as it sucked water from the air and diluted. Weekly testing.
Interested in how we got to -60 ask your questions in a new thread.
Ron
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
