Question regarding top link on BX@#
   / Question regarding top link on BX@# #1
Concordriver
Eastern Massachusetts
Kubota BX24
   / Question regarding top link on BX@# #2
By "ring" do you mean the little loop welded to the side of the toplink barrel?
You can see it very clearly here:
note that the area of interest on my BX1860 seems to be different compared to the BX24/25, presumably because of the BH attachment hardware.
Regards,
Wrooster
Yes. That is the loop I am referring to. On the BX24 it is closer to the tractor end of the top link. Do you know what that loop is for? In the photo I attached with my first post, there was a brass clevis pin inserted in that tractor's loop.
   / Question regarding top link on BX@# #4
That ring, if I follow what you're asking, is for putting a lever through like a flat bladed screwdriver so you can adjust the length of the top link when there's weight on it.
   / Question regarding top link on BX@# #6
On mine a 10" cresent wrench will slide in there and the jaws are just big enough to fit the lock nut on it!:thumbsup:
   / Question regarding top link on BX@# #7
I also hook my safety chains to it if it is the one I am thinking about.
   / Question regarding top link on BX@# #8
Note that the top link is reversible, if you take it off the tractor and put it on the other way 'round there is no difference. I agree with the poster above, the ring is useful for adjusting the overall length while the toplink is under load. Moreover, the little ring provides a useful place to attach the PTO shaft guard chains to. These chains prevent the shaft guard from rotating with the internal PTO shaft.
Regards,
Wrooster
2015 Audi A4 Sedan (A55758)
2015 Audi A4 Sedan...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
Link Belt Auger (A53316)
Link Belt Auger...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
