Quick Attach / Snow Pusher build
   / Quick Attach / Snow Pusher build
I got about 8 inches of snow last night and it worked great. I pile up all the snow behind my barn so the snow pusher is the best way to get it all back there. By doing this I won't get all the stones in my yard like I did when I just pushed to the side of the driveway. In the spring I will have a nice pile of stone to repair the driveway with.
   / Quick Attach / Snow Pusher build #12
Is the quick attach just for the plow or will it be used with the bucket as well? I don't see a way to keep a bucket from swinging if you tried to pull backward with it since there is no lower pin on the bucket side.
It will be used with the bucket and hopefully some pallet forks.
There is a plate welded at an angle on the bottom that keeps it from sliding down.
There are square u bolts that are hooked by rotating the pipe with the center lever. It is strong enough to lift the front of the tractor off the ground with the front tips of the wings. I tried to break it and bent the lever so I added the brace and its been good since.
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
6-NEW ALTERNATORS (A55745)
6-NEW ALTERNATORS...
43029 (A51691)
43029 (A51691)
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
