Quick Attach Toothbar
/ Quick Attach Toothbar #2
Forgive my ignorance, but why would you take it off?
Cleaning concrete maybe???:confused:
/ Quick Attach Toothbar #3
Looks like the answer to a question nobody asked. I can add or remove my toothbar in half the time and there are only two holes in the side of my bucket that do not affect performance in any way.
Who knows??? People have reasons I guess. I just don't see how this set up is an advantage.
/ Quick Attach Toothbar #5
You can't do a clean back drag with the toothbar on. I will often take it off when leveling and working with the box blade so I am can use the bucket to touch up places the box blade can get to.
/ Quick Attach Toothbar #6
X-2:thumbsup:
/ Quick Attach Toothbar #7
X-2:thumbsup:
Sure you can, I do it all the time with my ATI bar on the bucket.
I curl the bucket up and use the back edge of the bucket to back drag. No brainer.
/ Quick Attach Toothbar #9
I haven't taken the time to remove mine since I put it on (May). I have been too busy to do it. I have found it helps to spread that I can't with my box blade, as the teeth act as a "thickness" level when back blading. I do think I will be removing it for snow season.
I also put the teeth on the skid steer (only the 4' bucket). It is helpful to have a blade that has no teeth for those tight spots you can't get into with a box blade.
/ Quick Attach Toothbar #10
Bobcat OEM toothbars are removable, at least all the ones I've seen...
/ Quick Attach Toothbar #11
Same here...
They edited that video (note the "fades"). I'd guess it takes longer to install then putting the two bolts in and tightening the nuts.
But wouldn't it be easier to just remove two bolts when you want to take it off?
/ Quick Attach Toothbar #15
No one in particular.
OK...
Yeah, removing two bolts and pulling the tooth bar is a pretty easy task.
I've had mine close to 10 years. It was modified once when I went from a 54" bucket to a 61" bucket. Goes on in the spring and I remove it in the fall.
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2001 International 4000 DT 466E (A60462)
2001 International...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
