Quick, but fuel thirsty.
   / Quick, but fuel thirsty. #1
prs
Platinum Member
Logan, WV
JD 650, Ventrac 4500Z AJ02248
I mowed about 6 1/2 acres of rolling field today. The grass was heavy fescue and orchard grass, wet with dew as well as soggy or succulent with internal water. The under turf ground is very wet. Mowing quality was good, no problems with the clippings fouling the rollers or under deck of the contour mower. No wind rows or clumps left behind.
This machine is easy to maneuver and cuts a LOT of grass quickly. One down side seems to be fuel consumption. I burned a full 5 gallons on that one field. Full throttle and not letting RPM drag down under 3,000. My 33 year-old JD 650 diesel will do at least twice that work on 5 gallons. Then again, the JD 650 would only get a little more than half that field finished in the time it took the Ventrac and contour mower. So, I bought time. And that striped field looks good.
I have a small meadow to mow and a steep bank area, but this excess water is going to have to drain away before that. Maybe I can figure out how to work a GO-PRO camera for those jobs.
prs
   / Quick, but fuel thirsty. #2
If your happy w/performance what's little extra fuel. ;)
   / Quick, but fuel thirsty. #3
prs
The fuel consumption you experienced is reasonable for that engine and the type of conditions you were in. It is a small price to pay for the speed you can mow, the hills you can safely handle, and the quality of the work done.
Did you check the radiator screen? With a rear discharge deck out front of the tractor, it is easy for small clippings to be sucked up from the bottom. This is especially true when the turf and clippings are dry. You can monitor this by keeping a close eye on the temperature gauge. It will tell you a lot about what is on the radiator screen.
JackIL
   / Quick, but fuel thirsty. #4
That's about what my 31 Daihatsu would burn too, it likes it's fuel...especially when grunting. .i too was disappointed at first because compared to my Dixie chopper zero turn the ventrac burns twice - 3× the fuel with less power..but it's the nature of the beast..the 31 feels weak after running the dixies yanmar 3tn84 turbo ,50 hp at 2850rpm...78 ft lbs of torque swings that 72 inch deck with ease , cuts my 7 acres on about 1.5 gallons- 2 at the most..my ventrac. ..3.5-4 gallons on a normal cut. .
I cleaned the radiator screen before and after this job. Not at all disappointed with the performance, just noting the fuel use.
Another thing I noticed in my after job clean-up was that the sight tube for the hy-tran fluid was empty. If I have a leak, anyone have a suggestion for initial places to check. Parked on clean concrete floor, so maybe if there is a leak I will see a drip. The machine was cool at time of this check (I always try to re-fuel and such when it is cool), but it was cool when I noticed fluid in the tube initially a week or so ago. There is a reservoir above the tube where you add or fill and that tank is empty, but I suppose it is an expansion/collection tank.
prs
OK, No signs of leak on floor or anywhere on machine, no wetness, drips, or damp dust. I overlooked one aspect of the check procedure. I raised the main front hydraulic to max, but did not raise the AUX hydraulic. With both full up, the cold fluid level is just above the grommet where the sight tube disappears. This is shy of the correct level, but not by much. I will keep an eye on it for sure.
prs
   / Quick, but fuel thirsty. #7
Were you running in high range or low? If running in low the HYD drive motors will increase your fuel consumption almost 2X. High drive does require a bit more force on the control lever when on slight grades, but is the most efficient way to move if grades or slopes aren't significant. When mowing my acreage I hit the hills or slopes first in low range, then shift to high for the remainder.
The mower is a mechanical function that requires the same amount of power per your speed. How you attain that speed via the HYD motors can make a huge difference in fuel used.
As is always the case operate in the range where you are comfortable! I used a lot more fuel during my early learning hours in the Ventrac seat. Operating in low range forgives a lot of sins. Experience is always the best teacher!
So far, all of my work has been low range. I have tried high range for tramming on the driveway, but my land has no flat and very little gentle slope. With the gear drive CUT I typically mow in 5th (8 gear tranny), but some even in 2nd. Shifting the Ventrac from low to high is pretty time consuming and although I could stop and so shift for the downhill or across hill runs, it would probably be quicker to just stay in low range and keep on going. Time will tell.
prs
   / Quick, but fuel thirsty. #9
I've only had my 4231 in low range 3x, in a few yrs, when I was pushing logs with the slip scoop, and once towing my equipment trailer (about 4k lbs), never used low mowing, seems like you'd only need it on the steepest hills. I bought my machine with cable broken to the rear axle so switching to low requires you to put lever in low, then get off walk around back and reach in above the weights and manually push the link age putting the rear in low . switching back to high is easy, just flip the lever and both go to hi.., as the broken cable works fine in push mode.
   / Quick, but fuel thirsty. #10
prs
prs
How many hours did it take you to complete the 6.5 acre field ?
Knowing that we can divide the total fuel consumed (5 gallons) by the number of hours. ( example if you consumed 5 gallons of fuel in 3 hours that would be a fuel consumption rate of 1.67 gallons per hour ).
Enjoy the quick machine. Plus we always like pictures and videos.
Wayne
The dealer's set-up man advised to use this combination at or near full engine speed and to not bog the machine down on slope; that is, to reduce the speed to keep RPMs at or above 3,000 on the slopes. On my land, with this mower, it seems as if low range is going to be used a lot, if not most of the time. It may be because my machine is not worn in yet, but shifting from high to low or back has me coming to a complete stop, pulling a safety pin, unlatching the lever from its lock notch, then teasing the tranny with the speed/direction lever back and forth gently to allow the lever to go all the way to the other lock notch, and then re-inserting the safety pin in the new location. Its no big deal, but not something I want to do every few minutes in the rolling fields. Of course, when Big Oil finagles the price of fuel back up to about $4.00/gal, I might have a change of attitude.
prs
   / Quick, but fuel thirsty. #12
No shifter safety pins on the 4100 / 4200 tractors I own. There are detents that need to be engaged. Generally can shift on the go once you get the hang of it. I'm surprised that Ventrac has not developed a servo to allow an easier range selection. The lever is not especially user friendly. The more electrical tape wrap around the end makes the shift less painful.
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
2021 HYUNDAI ROBEX 35Z-9A EXCAVATOR (A60429)
2021 HYUNDAI ROBEX...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
